having cooling problems
Old Jan 1, 2003 | 01:42 AM
RuthlessEF-9's Avatar
Default having cooling problems
ever since i put my turbo on in my 89 civic 4dr i've been running on the really warm side. you think if i run thermal wrap on my DP would keep my temp down
Old Jan 1, 2003 | 01:47 AM
LsVTeCTuRBo17's Avatar
Default Re: having cooling problems (D16z6turbs)
Yea it may but not drastically. Does it over heat? How much of the overheat gauge is reading?
Turbo motors are known to be a little more on the hotside. Also are you using a stock radiator, if so swap that out and get a fluidyne.
[Modified by LsVTeCTuRBo17, 2:48 AM 1/1/2003]
Old Jan 9, 2003 | 08:54 AM
Default Re: having cooling problems (LsVTeCTuRBo17)
it doesnt overheat but i got a spoon radiator cap and that seem to help me out
so thanks for the help
Old Jan 9, 2003 | 10:54 AM
Doodoo's Avatar
It shouldn't overheat unless your cooling system is jacked up. I have an 88 and it only overheated when something wasn't working right. Check fan, thermostat, coolant, radiator cap, and radiator for any faults.
delsolnewkid
14
Feb 6, 2009 11:36 AM
K2sInteg98
Feb 21, 2008 12:19 PM
white_crx_si
Jul 20, 2005 10:36 PM
97dc2
Jul 12, 2005 09:00 PM
JO
Aug 31, 2003 05:46 PM
