most important gauges???
Old Dec 31, 2002 | 12:28 AM
91hondacrx's Avatar
Default most important gauges???
What do you guys
think are the most important gauges to have in a CRX?? IF it is not turbo charged, has a stereo, and new motor(rebuilt)? I know i want a air to fuel gague and i was just wondering what would be a good idea for the rest of the stuff so i know exactly what is goin on with my motor so i know if something is wrong.
Thanks,
Matt
Old Dec 31, 2002 | 04:58 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: most important gauges??? (91hondacrx)
oil pressure
i have an a/f ratio gauge also(autometer)...its kinda not really that useful. its not the most accurate thing in the world, but it will tell you if you are way off...and i may be wrong, but i don't think that it works with nitrous, you can use it but the readings are incorrect.
fuel pressure get the b&m one...it works and is cheap - even though its a 3 dollar gauge and a 50 cent banjo bolt that sells for 30 dollars it is still cheap compared to others.
Old Dec 31, 2002 | 05:29 AM
spun Vtec's Avatar
Default Re: most important gauges??? (fastcrxsi90)
air fuel
oil pressure
water temp
boost
Old Dec 31, 2002 | 05:33 AM
BoostedED9's Avatar
Default Re: most important gauges??? (4gsicivichatch)
oil psi, watertemp or egt.. do not go out and waste money on a a/f gauge, you will just pay for a little annoying lightshow that is not even close to accurate
Old Dec 31, 2002 | 06:27 AM
lazy bum shaughn's Avatar
Default Re: most important gauges??? (BoostedED9)
True.
I think for all motor, the important ones are, oil pressure, EGT temperature, fuel pressure(most people leave it under the hood, by the fuel pressure regulator), oil temperature.
*edit* Oh yea, can't forget the big fat 5" Tach too.
[Modified by lazy bum shaughn, 7:27 AM 12/31/2002]
Old Dec 31, 2002 | 08:32 AM
91hondacrx's Avatar
Default Re: most important gauges??? (lazy bum shaughn)
Wouldn't the Hot cold gauge take care of the oil temp or is that just the water temp?? So no air fuel, oil temp, fuel pressure, oil pressure, what is the egt gauge? Do i want the adjustable fuel pressure regulator along with the gauge? or is that worth it?
Thanks,
Matt
Old Dec 31, 2002 | 10:02 AM
Urban Business
Guest
Posts: n/a
Thanks,
Matt
egt is exhaust gas temp. its a much more accurate way of monitoring your a/f ratios. if you have no clue as to what temp you should be at or want to get at dont bother. if you have no means of adjusting your mixture, dont bother. in that case buy a digital a/f guage by nordskog ($28 at summit). they are not as accurate as a wideband o2 sensor or egt but they will still save your ***. and thats whats most important.
megotvtec
Apr 28, 2004 12:31 PM
JSR3STS
Feb 9, 2003 05:21 PM
E Swift
Jun 5, 2002 08:34 PM
Snafu-Si
May 3, 2002 09:27 AM
DC2R714
Nov 28, 2001 09:13 AM
