Diff noises?
Old Dec 30, 2002 | 01:07 PM
skunked's Avatar
Default Diff noises?
Has anyone had any experience with a differential (open) making clunking noises before it goes out? Thanks for the info in advance.
Mat
Old Dec 30, 2002 | 01:15 PM
Spade's Avatar
Default Re: Diff noises? (skunked)
Change your tranny fluid
Old Dec 30, 2002 | 01:17 PM
skunked's Avatar
Default Re: Diff noises? (Spade)
Just did about 1K miles ago.
Any other Ideas?
Old Dec 30, 2002 | 01:20 PM
Spade's Avatar
Check your CV boots.
Old Dec 30, 2002 | 01:22 PM
skunked's Avatar
Already did. Doesn't sound like a axle problem.
Old Dec 30, 2002 | 01:25 PM
Spade's Avatar
Best bet is a free estimate from a local tranny shop.
Old Dec 30, 2002 | 01:57 PM
skunked's Avatar
Thanks for your help but I still would like to know if anyone has had any experiences with thier diff's becoming noisey before breaking completly.
Old Dec 30, 2002 | 06:17 PM
CHEETAH's Avatar
the clunking means there is excess play in the spider gears ... time for new diff ... pm me i have lots of open diffs, but hey its XMAS time, perhaps Santa can bring you one of those LSD things ...
greg
Old Dec 31, 2002 | 04:52 AM
Mista Bone's Avatar
D Tranny Guru
Is the tranny a L3 in a SOHC 88-91 CRX/Civic???????
Non harden pinion shaft wore through, snapped, destroyed the casing/diff/gears.
Old Dec 31, 2002 | 07:21 AM
skunked's Avatar
Default Re: Diff noises? (Mista Bone)
Mista Bone,
Y80, GSR tranny with 115K miles and probley about 40 passes on slicks.
Old Dec 31, 2002 | 07:28 AM
skunked's Avatar
Default Re: Diff noises? (CHEETAH)
greg
Thats what I thought may be going on. The car has seen allot of low 13 and a couple high 12 sec passes on slicks along with over 115K street abuse miles. Thanks for the info Greg and I will get back to you on the LSD.
Mat
Old Dec 31, 2002 | 07:33 AM
CHEETAH's Avatar
greg
Mat
ok matt, I dont have an lsd for sale, was only recommending that nows the time to upgrade if the diff is bad and if you've been a good boy santa may bring to you ... if you want a KAAZ, call up Ray @ KAAZUSA, tell him you want the special thats going on, let him knwo I sent you.
GL
Greg
Old Dec 31, 2002 | 07:48 AM
skunked's Avatar
GL
Greg
I will definetly take full advantage of this opportunity to upgrade to an LSD.
Thanks again.
Mat
turboef90
Transmission & Drivetrain
Sep 8, 2014 05:52 PM
J0n1na
Mar 21, 2011 08:23 AM
JoeB18R
Dec 25, 2004 05:35 AM
chambersef8
May 2, 2004 02:46 PM
