LS/Vtec Head bolts
Old Dec 30, 2002 | 12:47 PM
zCivic's Avatar
Default LS/Vtec Head bolts
Which do I use for the head bolts or does it matter. I have a LS/Vtec in the works and need to know for my shopping list.
Old Dec 30, 2002 | 01:18 PM
Jeff C's Avatar
Default Re: LS/Vtec Head bolts (zCivic)
ARP B18C1 Head studs
Old Dec 30, 2002 | 01:32 PM
zCivic's Avatar
Default Re: LS/Vtec Head bolts (Jeff C)
Ok so I need v-tec head bolts correcto???
Old Dec 30, 2002 | 02:45 PM
riceboy's Avatar
he said studs, not bolts, don't use head bolts on an lsvtec.
ARP VTEC head studs.
but if you wanna use bolts, be my guest...they would need to be vtec bolts, but like he said
use head studs
Old Dec 30, 2002 | 08:06 PM
zCivic's Avatar
Default Re: LS/Vtec Head bolts (riceboy)
Damn man got the point............
Old Dec 30, 2002 | 08:10 PM
Jeff C's Avatar
I got mine from summitracing.com for $116 plus shipping.
Part #- ARP-208-4303
Item description:Acura: All B18CI, 11mm, chromemoly steel, black oxide finish, head stud kit ...
Good luck!
Old Dec 30, 2002 | 09:39 PM
zCivic's Avatar
Ok I've looked them up look pretty good. quick question are the boxed off so you can bolt them directly to the block or do you have to figure out a way to make them stay with out backing out, locktite, use two bolts and back them off or what. or does it have pretty good instructions. Do the have main bolts also for the GSR.
[Modified by zCivic, 11:04 PM 12/30/2002]
Old Dec 31, 2002 | 06:23 AM
GM2000ITR's Avatar
New User
Why not?
Old Jan 1, 2003 | 07:40 AM
Jeff C's Avatar
I am not sure if they are boxed off or not, but I have never heard ot them backing out. I am not sure if they make main studs or not...summit dosent have them on their site though.
PS. Personally, I dont see why you could not use bolts.
Old Jan 2, 2003 | 05:59 AM
zCivic's Avatar
yeah just noticed that also. Appreciate it. Also learned that GS-R bolts 1mm longer
Old Jan 2, 2003 | 06:08 AM
1bad-eg's Avatar
Default Re: LS/Vtec Head bolts (GM2000ITR)
Yeah, why not??
Old Jan 2, 2003 | 07:21 AM
V3locity's Avatar
Default Re: LS/Vtec Head bolts (1bad-eg)
http://www.arp-bolts.com/pages/produ...headstuds.html
Bolts have threads on one end, where studs are threaded on both ends. The studs are going to be alot stronger hands down. Check out that link, and it will all make sense. Get the studs.
Old Jan 2, 2003 | 08:33 AM
CHEETAH's Avatar
this is not true, you can use GSR or b16a bolts on them, preferable GSR because they are longer. You can also use 8 of the 10 LS bolts and order 2 new LS bolts from the dealer ... the 2 originals are very long and will not work.
If you want beefy clamping then the ARP but that is a PITA if you have to take off and put on ... but to each his own ...
as for ARP studs, DO NOT USE LOCTITE, you are suppose to screw in hand tight, all of them should be the same level when screwed in hadn tight, if they are not then the ones that are higher prolly have oil or liquid in the block hole and you need to unloosen and tighten more until it is fully seated hand tight ... when you clamp on the washer and nuts then it will torque to specs... you can goto 71 or so ft-lbs with the arp moly or 90+ ft-lbs iwht 5/30 oil.
Greg
Old Jan 2, 2003 | 09:33 AM
zCivic's Avatar
Default Re: LS/Vtec Head bolts (CHEETAH)
thanks for all the info, gonna get the studs in a while, put them in even height at hand tight w/ 5w30 and torque them down to 90ft/lbs. Sound about right??
Old Jan 2, 2003 | 09:44 AM
CHEETAH's Avatar
yah, and oil the side where the nut clamps too ... oil before putting head on cause its hard to get to the threads after the head is on ...
greg
Old Jan 2, 2003 | 10:58 AM
zCivic's Avatar
oh yeah forgot, put the studs in prior to placing the head on the block right?? then oil where they stick out of the head??
Old Jan 2, 2003 | 04:49 PM
CHEETAH's Avatar
both ends of the studs need oiling or dipping in the oil then screw into block hand tite then put head on after then washer then nut then torque same method as manual, 22ft lbs then like 50 ft lbs then whatever you plan 90 ft lbs or so ... The 3rd is not in the manual, thats how i do it which is safer as it *settles* very nicely
greg
brian3676
Dec 14, 2005 05:45 PM
frostt3ch
Dec 31, 2003 08:18 PM
riceball777
Dec 9, 2003 05:08 PM
riceball777
Oct 25, 2003 01:56 PM
riceball777
Oct 22, 2003 04:22 PM
