axle/rotors/calipers locked up please help!
Its either something with one of the three. I put the b16 in my hf i switched rotors, calipers, brakepads everything from a 90 dx. when i tighten down my axle nuts it like actually tightens the wheel somehow so it doesnt want to spin. i also got the 90 ls integra axles. the right seems to be to tight in the area but it wont fit on the other side. i am thouroghly confused and irratated. oh yea if i loosen the axle nuts the rotors and brake pads grind like ***** f___s. i know i need to drive that one out but i dont understand the axles? are they in backwords, right and left and i am just not forcing it in enough or what. oh if it matters my ebrake doesnt work at all, pulls right up doesnt do a damn thing. thanks
chris
[Modified by 88whitehf, 7:45 AM 12/30/2002]
chris
did you change the knuckles too from the dx if yes than i dont know what could it be also try just putting the knuckles from the dx and put back all the parts from your HF
Agreed. The brake rotor should be albe to be turned freely without the axle in. When you put the axle in the rotor should still spin freely unless it is binding on #2 in this picture.
so remove the # 2 on the picture on both sides? and i should be all set. also the hf hubs are way to small for the axles. thanks i will give it a try.
chris
chris
When using the 90-93 LS axles you need to also use the LS intermidiate shaft from the S1 trans. You should also be using the Si hubs from either civic/crx. You can also use the 90-91 LS integra's or the civic EX.... Both of which you also need the knuckles,hubs,rotors,calipers, and they give you a factory big brake upgrade, same as the JDM SIR.
teknohatchie91
12
May 31, 2005 11:33 AM
average_psi
Nov 8, 2004 08:45 AM
sloaccord96
May 24, 2002 11:05 PM
