Swap wiring question
Im almost to the wiring part of my swap, and i have a quick question.
When i run a wire to the ecu plug (example: running vtec wire from the motor, to the plug on the ecu) how doesthe wire connect into the plug? Im not really familiar with the plugs, is there a pin the wire connects to, or do i have to purchase something to connect it into the plug?
TIA
TIA
I'm at the same point in my swap except its a JDM GSR from hmotorsonline.com and people said you have to bust open the ecu plug and salvage the pins from there that are not being used like AC and use them for what you need like vtec. be careful not to brake the plugs. search and you will find pictures on how to do it i found them yesturday but don't have the link sorry
iliv2xlr8
Mar 4, 2009 06:16 PM
shbrown
Aug 11, 2005 04:51 PM
