FMU vs. SMC+ and 450cc injectors, on LS motor
Old Dec 29, 2002 | 11:16 AM
ls-t del sol's Avatar
Default FMU vs. SMC+ and 450cc injectors, on LS motor
I have a b18b motor, im gathering up all the turbo parts for it now. I plan to run 7-9 psi on it. I will be using either a t3/60-1 turbo, or a 57 trim t3/t04e. I have the dsm injectors already, but after seeing some impressive results with using a fmu, i may sell them and buy a vortech fmu. The motor will be stock internally (for now) and I prefer reliablility over maximum power. Any suggestions? Also, which turbo would you guys choose, between the two listed above? Thanks!
[Modified by SolReaver, 8:16 PM 12/29/2002]
Old Dec 29, 2002 | 11:19 AM
b16ahybrid's Avatar
Default Re: FMU vs. SMC+ and 450cc injectors, on LS motor (SolReaver)
I've never used the smc/dsm injector route but from what i hear it's a decent set-up.I'm using a fmu and it works fine no tunability though.
I'm using a t3t40e (.57/.63) and i love it....i recomend that one....but once again i've never used a t3 60-1 either
Old Dec 29, 2002 | 08:27 PM
Default Re: FMU vs. SMC+ and 450cc injectors, on LS motor (b16ahybrid)
Cool, im kinda leaning towards the FMU route now. It worked perfectly on my old motor/turbo setup. Anyone else?
Old Dec 30, 2002 | 06:56 AM
johnisenglish's Avatar
I'm in the same boat as you, but I'm just running an FMU and Inline Fuel Pump for now, with the intent of upgrading to a standalone later
Old Dec 30, 2002 | 08:15 AM
Islander's Avatar
New User
What's the maximum amount of boost you recommend using the turbo you have?
Old Dec 30, 2002 | 08:55 AM
b16ahybrid's Avatar
Default Re: FMU vs. SMC+ and 450cc injectors, on LS motor (Islander)
depends on a lot of things. Engine is it built or stock, tuning with stand alone or using fmu or smc? stuff like that..but generally 10psi or less for a stock engine.But i believe that the turbo i'm using is efficient up to about 18psi before adding to much heat...
[Modified by b16ahybrid, 9:56 AM 12/30/2002]
Old Dec 30, 2002 | 09:08 AM
gtcali's Avatar
If anybody needs a 12:1 Vortech FMU, I have have one collecting dust.
Old Dec 30, 2002 | 10:39 AM
SoulSurfer's Avatar
Default Re: FMU vs. SMC+ and 450cc injectors, on LS motor (gtcali)
Everyone I know who switched from an FMU to the SMC loved it. But if you're just looking for reliability then the FMU should keep it more simple.
Old Dec 30, 2002 | 12:41 PM
SIK IN DA HED's Avatar
New User
Default Re: FMU vs. SMC+ and 450cc injectors, on LS motor (LSDelSol)
you can actually use a AFC to tune out the richness at higher rpms with the fmu setup... but i would rather save the money for hondata... so its totally up to you on how you want to tune things out.
Old Dec 30, 2002 | 06:35 PM
Islander's Avatar
New User
I don't want to sound like a fool, but what's the 'SMC'?
Old Jan 3, 2003 | 09:17 PM
Anyone else have any other opinions?
Old Jan 3, 2003 | 09:50 PM
SoulSurfer's Avatar
Search for "SMC" and you will find a few helpful posts.
Old Jan 3, 2003 | 10:16 PM
Joseph Davis's Avatar
$20 worth of electronics sold for $125.
Check this, as it is "the same" situation as it has to do with boost via manipulation of the MAP sensor signal. AFC and MAP (and SMC) boost hacked vehicles run too much ignition advance in the boost range. Here: https://honda-tech.com/zerothread?id=373528
Old Jan 4, 2003 | 10:23 AM
Islander's Avatar
New User
Default Re: FMU vs. SMC+ and 450cc injectors, on LS motor (J. Davis)
Anyone has pics of the SMC unit? It's not the SMC unit sold by Autotronic right?
motorhead_guy
Jun 17, 2006 08:49 AM
busychild
Oct 14, 2003 10:32 AM
MikeMAN
Feb 1, 2003 10:23 PM
TurbothisLS
Aug 25, 2002 05:39 PM
