How's this setup for a D16a6?
Old Oct 9, 2003 | 10:21 AM
busychild's Avatar
Default How's this setup for a D16a6?
-Garrett T3 turbo .48 a/r exhaust and .42 a/r compressor with a 50 trim. no shaft play.
-Drag manifold.
-supra 430cc top feed injectors w/ all clips and resister box
-vortech FMU w/ 12.1 disk.
-nissan SR20 blow off valve
is something missing? what can I improve?
Reason I am asking is that I am about to buy this setup.
Old Oct 9, 2003 | 10:23 AM
Slammd Sol's Avatar
Dump the FMU and get an AFC to control the 430's
Old Oct 9, 2003 | 10:25 AM
busychild's Avatar
Default Re: (Slammd Sol)
What benefit would that leave?
. Thanks for below
Old Oct 9, 2003 | 10:27 AM
Slammd Sol's Avatar
You dont need an FMU if your going to replace the injectors.. and if you replace the injectors you need the AFC to control them so you dont run to rich.
Old Oct 9, 2003 | 11:19 AM
busychild's Avatar
Thanks, what about the D16a6? anything I could do to strenghten the internals? Anyone with a similar setup?
Old Oct 9, 2003 | 11:22 AM
havok hybrid's Avatar
Default Re: (busychild)
I have had many turboed sohc's . I went from the fmu to the AFC and WOW, there is nothing like it.. its so much better.
As for the internals, what do you want to get out of the car and setup. I would do at least a block gaurd and maybe inline pro headgasket or head studs too.
I have ran 10-11 psi on stock bottom ends easy.
Search for VAFC HACK*
Old Oct 9, 2003 | 11:42 AM
busychild's Avatar
Default Re: (havok hybrid)
In the end I want to run high 13s consistantly and have decent reliability out of the motor.
Modified by busychild at 1:50 PM 10/11/2003
Old Oct 14, 2003 | 10:32 AM
busychild's Avatar
Default Re: How's this setup for a D16a6? (busychild)
-Drag manifold.
how about all this for 500? good deal?
tonezilla
Jan 13, 2004 09:09 PM
X2BOARD
Aug 11, 2003 08:18 PM
freeplay
Dec 1, 2002 09:41 AM
TurbothisLS
Aug 25, 2002 05:39 PM
