fluid damper?
Old Dec 28, 2002 | 09:10 PM
rpm9100's Avatar
Default fluid damper?
do you need it?
what exactly is it there for?
I keep getting mixed reviews.
Old Dec 29, 2002 | 10:21 AM
rpm9100's Avatar
Default Re: fluid damper? (rpm9100)
no one?
Old Dec 30, 2002 | 09:16 AM
rpm9100's Avatar
Does anyone know what a fluid damper is?
it sits on the end of the fuel rail, and I would like to know if I can remove it.
Old Dec 30, 2002 | 09:25 AM
Desslok's Avatar
You mean a fuel pressure regulator?
Old Dec 30, 2002 | 03:46 PM
rpm9100's Avatar
Default Re: fluid damper? (sp)
<U></U>
no, on the exact opposite end of the fuel rail. It is transparent white in color.
thanks for the reply.
Old Dec 30, 2002 | 05:38 PM
SuperSH's Avatar
Do you mean the plastic cap that covers the nut that holds the banjo fitting to the fuel rail?
Old Dec 30, 2002 | 11:29 PM
rpm9100's Avatar
Default Re: fluid damper? (SuperSH)
YES
I have been told it balances the fuel in the rail.
I have seen some set ups without it. I would just like to know the ill effects if any.
Old Dec 30, 2002 | 11:51 PM
Benny Hinn's Avatar
I don't know about "balancing the fuel", but it dampens the "vibration" in the rail caused by the injectors. When the injector opens, the fuel starts to flow through, when it closes, the momentum of the fuel will continue and then bounce back from the injector nozzle back to the rail.
CoastalSi
Dec 21, 2010 08:01 PM
krazyhmongboi
Mar 7, 2007 05:06 PM
mister2racer
Apr 16, 2004 03:56 PM
Bantam
Mar 7, 2003 08:58 AM
digitalspice
Dec 18, 2001 07:57 AM
