Air/Fuel Ratio Gauge
Old Dec 28, 2002 | 05:27 PM
MugenPoweredLude's Avatar
Default Air/Fuel Ratio Gauge
I had my a/f gauge installed a while ago and i was just wonderin if its supposed to be goin back and forth from lean to rich rich to lean when at highway speeds and local driving??? i know it stays rich...way toooo rich at WOT. just wonderin..never had or saw an a/f gauge before so i was just wonderin if its normal.
Old Dec 28, 2002 | 05:39 PM
gsrhatch530's Avatar
Default Re: Air/Fuel Ratio Gauge (MugenPoweredLude)
yes, it doesn't read correctly tell you are at WOT.
Old Dec 28, 2002 | 07:12 PM
DirtyLude's Avatar
Default Re: Air/Fuel Ratio Gauge (gsrhatch530)
It reads just fine when you are not at WOT. When cruising the ECU uses the O2 sensor to control fuel on closed loop mode. It cycles back and forth between rich and lean for emmissions and fuel savings reasons.
Explanation of Closed Loop:
http://www.autoshop101.com/forms/h44.pdf
Standard O2 sensors:
http://www.autoshop101.com/forms/h37.pdf
Old Dec 29, 2002 | 12:18 AM
1fast5gp's Avatar
Default Re: Air/Fuel Ratio Gauge (DirtyLude)
you probably got a Autometer gage, those gages are worthless.. you need a Greddy AF gage or a Apexi AF gage and a wideband o2 sensor it will be soo much more acurate
peddyeye
Dec 1, 2008 01:52 AM
ballinthavx
Oct 23, 2005 11:56 AM
wrEcKed_LX
Apr 26, 2005 03:56 PM
doublejz
Jan 14, 2004 05:31 AM
swlabhot
Jan 20, 2003 06:50 AM
