How to check SRS light code??
Old Dec 28, 2002 | 09:18 AM
HXMan's Avatar
Default How to check SRS light code??
I am about to sell a CX of mine, and I need to know how to check the SRS code to see if I just need to reset the system...or if it is a big deal. Thanks.
-Levi
Old Dec 28, 2002 | 10:41 AM
tnbigdawg's Avatar
Default Re: How to check SRS light code?? (HXMan)
try a search. I've seen this thread before, it shows how to reset it.
Old Dec 28, 2002 | 11:03 AM
HXMan's Avatar
Default Re: How to check SRS light code?? (tnbigdawg)
Yea, I just reset in on the first try. Now to figure out another problem.
Old Dec 28, 2002 | 02:50 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Try using a paper clip (unfolded) to read the ecu code. The panel under and to the right of the glove box will need to be removed to gain access to the ecu pins. I cannot remember offhand what color the harness is, but what you need to do is place a conductor (the paper clip) into both slots of the pin. This will allow you to count the number of pulses the ecu goes through both fast and long pulses. Make sure the key is turned to accessory, this should allow you to read the ecu.
BLUE EH3
Jan 12, 2007 01:00 PM
stockintegra
Mar 27, 2004 02:13 PM
DiSbaDbOi
15
Dec 12, 2003 09:44 AM
NoLipRacen
Jan 29, 2003 11:27 PM
