Different VTEC for ITR intake manifold?
Old Dec 28, 2002 | 02:53 AM
Norcalstoppy's Avatar
Default Different VTEC for ITR intake manifold?
I remember RK and I talking about this quite some time ago, but we couldn't really come to a conclusion. He was saying that in order for an ITR or Skunk2 IM to work well with a GSR, it's better to raise the vtec engagement point to stock itr rpm, than the gsr rpm of 4400. Why would raising the vtec make a difference in power? Also wouldn't the top end be the same no matter what?
Jay Kim
Old Dec 28, 2002 | 07:09 AM
myhatchrips's Avatar
Default Re: Different VTEC for ITR intake manifold? (AllMotorMonster+)
should help
[Modified by myhatchrips, 8:12 AM 12/28/2002]
Old Dec 28, 2002 | 07:11 AM
well first of all, the gsr and type-r run different ecus. therefore different fuel maps and igntion timing (correct me if im wrong)? second yes raising the vtec point to 5700 rpm and running the skunk2 manifold will offer a gain in power in most cases. remember vtec operates only if , engine temp, oil pressure,vss, some other ish is functional. honestly turning or lowering the vtec point is to smoothen out the powerband of any vtec powerplant depending on what you have done to it
goblynn93
24
Jan 29, 2012 12:14 AM
GsRwHiTe
Feb 15, 2004 03:01 PM
vietshinobi
Oct 14, 2002 08:45 AM
hYpE-R-29
May 28, 2002 07:59 PM
arete213
Sep 10, 2001 08:44 AM
