Dim Drivers side headlight
I just bought an 87 Honda Accord, And the drivers side headlight is dim. I thought maybe it was just the light so I swithed it with the passenger headlight and it was still dim. Any suggestions on what this might be? Thanks for any info.
Ive Wiggled wires and I checked all fuses. Im stumped, Maybe I will pull out the volt meter and see what kind of voltage I am getting. Even when you flip the high beams it still stays dim. But the light shuts off for a second, then comes back on.
my mom just bought a 91 accord wagon a few days ago and it had a dim driver's side headlight. I just figured that it was a bad bulb, and swapped it out. still dim. checked the fusebox under the hood and saw that there was no fuse in the slot for the driver's side headlamp. I stuck in a 20 amp fuse and everything's fine now.. maybe you should check those fuses out.
I replaced the bulb in mine and it does the same thing. I'm betting it's the plug or wires behind the plug.
[Modified by Stew Pidasso, 1:06 PM 12/30/2002]
Good deal. Do they sell the factory style plugs or is it just a universal fit for that particular headlight?
Got the part at Auto Zone-part #85810
The old wires were missing insulation and broken. When I pulled on them, they pulled right out. The old plug was very corroded too. I bought the new plug and spliced it in. It wasn't too hard.
Old wires and plug...
nausicaa
Oct 23, 2008 05:00 PM
gold_ef
Oct 20, 2006 02:43 PM
