Fitting 18's on a 96-00 Civic????????
Old Dec 26, 2002 | 10:17 PM
lowcivex's Avatar
Default Fitting 18's on a 96-00 Civic????????
I have 18*7.5 rims with 215/35/18 inch tires. My car is dropped with eibach sportlines. I did not put the rims on the car yet. I was wondering if anybody had a similar set-up because i wanted to know if they had to do anything to prevent from rubbing ( like bend up the inner fender in the wheel well or take out the fender liner ).
Old Dec 26, 2002 | 10:55 PM
Civicboy's Avatar
Default Re: Fitting 18's on a 96-00 Civic???????? (lowcivex)
I had 18s on my 98 and it sucked. rubbed all the time, when I went over bumps, turned to sharp. It sucked.
Old Dec 26, 2002 | 11:37 PM
Buckshot's Avatar
Default Re: Fitting 18's on a 96-00 Civic???????? (Civicboy)
yes they will fit....only if ur a rice boy tho
Old Dec 26, 2002 | 11:43 PM
lowcivex's Avatar
Default Re: Fitting 18's on a 96-00 Civic???????? (Buckshot)
in the middle of building my gsr motor for a turbo (NO RICE HERE)
Old Dec 27, 2002 | 03:05 AM
RedRacer's Avatar
New User
Biggest problem will be the width 7.5" vs. 7". I'd be willing to bet that your rims are running a 40 mm offset also. With that being said, then your problem will not be the rubbing from the vertical motion (bumps and such) but when you turn your wheels it will rub on the inside of your fenders on the metal and grind it down. Especially with the drop that the Sportlines provide I wouldn't do it with it that low.
Oh and with a build motor and a Turbo you will probably want something with which you can get more tire on. For example a thicker tire (45 vs. 35) will help with traction and should help make wheel hop not such an issue. Just food for thought.
Old Dec 27, 2002 | 04:36 AM
SPORT INJECTION's Avatar
dubs - 2 = like whoa
Old Dec 27, 2002 | 05:59 AM
acteg94's Avatar
Default Re: Fitting 18's on a 96-00 Civic???????? (99MRSI FOR SALE)
why 18's ??
Old Dec 27, 2002 | 06:05 AM
LSBeast's Avatar
Default Re: Fitting 18's on a 96-00 Civic???????? (acteg94)
Old Dec 27, 2002 | 06:16 AM
Fez's Avatar
Fez
My boy has 19's on his civic but he has ground control coilovers, no rubbing on his sheet.
You need coilovers to make it sit right.
vinceg143
Apr 22, 2009 07:45 PM
SOL-Hatchback
Apr 12, 2007 10:32 PM
Money $hot
18
Jan 5, 2004 11:50 AM
Hatchtrap
Jan 29, 2003 11:03 AM
All Motor R
Jul 31, 2002 01:45 PM
