Installing Toda cams spec B's
Old Dec 25, 2002 | 11:03 PM
Carnage24's Avatar
Default Installing Toda cams spec B's
I have a 2000 4DR GSR and i'm installing Toda cams spec B's, cam gears, valve springs and Ti retainers. My question is how often do i have to change my timing belt with these type of cams. I thank you in advance for all your input. Duce and be safe.
Old Dec 25, 2002 | 11:38 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Installing Toda cams spec B's (Carnage24)
get a better one too =P
Old Dec 26, 2002 | 06:54 AM
advanracing62's Avatar
Default Re: Installing Toda cams spec B's (dLo GSR)
I'd probably just throw a Power Enterprise belt on there... tons stronger than the stock one and just the same, as I can see, as the Toda..less $$$ though
Old Dec 26, 2002 | 12:16 PM
jr_istheman's Avatar
Default Re: Installing Toda cams spec B's (advanracing62)
I'm interested too... with those specs, how often would the timing belt have to be changed? either if it was a stock on or a PE one? thanks! TTT
Old Dec 26, 2002 | 01:19 PM
Shawn C's Avatar
In The Garage
Default Re: Installing Toda cams spec B's (jr_istheman)
im pretty sure toda makes a really strong timing belt. if youre going all toda, then get it. if you do a lot of engine building, then you should be able to keep a good eye on youre belt. plus, stock timing belts are weaker than good ones mainly at high rpms. thats where youre gonna break one.
Old Dec 28, 2002 | 06:22 PM
OEMJDM's Avatar
how much does a Toda or Power Enterprise belt go for?
Old Dec 28, 2002 | 06:35 PM
tominos's Avatar
Default Re: Installing Toda cams spec B's (b20b4me)
i've never heard of a power enterprise belt before. where can i find info on this?
Old Dec 29, 2002 | 04:39 AM
Carnage24's Avatar
Toda timing belt goes for $150-180.
Old Dec 29, 2002 | 11:27 AM
you can contact www.JDMSPECPERF.COM for the PE belt
Old Dec 31, 2002 | 10:32 PM
still no comment on how often they should be changed? I was thinking that after 60k, they should be spent, just as a precaution... anyone with a better input than me? thanks!
Old Jan 1, 2003 | 08:18 AM
eg6ajk's Avatar
with high lift cams, most guys on the ITR fourm came to conclusion , that is should be done at least at 20k miles or so. do search they have been few with B's and belts wearing out. rember these cams might be streetable but they weren't designed to be easy on your equipment. as extra percaution, go with the PE or Toda belt, extra $150 is nothing when you look at the consequences of a broken belt ... I check all my components every oil change...pop open the valve cover, look at the whole valve train. check and if necessary the torque all the mounts, belts and pieces.
Old Jan 1, 2003 | 08:44 PM
Default Re: Installing Toda cams spec B's (eg6ajk)
20k for the OEM belt, but how about the PE belt? I presently have a PE belt with 2500 miles on it and was curious as to when would be a good time to change it. (got B's and toda springs) anyone with acutal experience with this PE belt that needed change? thanks!
Old Jan 2, 2003 | 04:57 AM
anyone?
Old Jan 2, 2003 | 05:53 AM
JeffNA's Avatar
ITR Forum is a good place to ask.
Old Jan 2, 2003 | 06:02 AM
CHEETAH's Avatar
the PE or Toda belt wil last a good 60-70K miles with big cams ...
Greg
Old Jan 2, 2003 | 02:12 PM
Default Re: Installing Toda cams spec B's (CHEETAH)
thank you Greg with your answer. 60k it is then
kgibson16
23
Jan 26, 2006 04:21 PM
chet
Feb 8, 2004 02:47 PM
integrasi
Sep 21, 2003 09:30 PM
DA MUGEN 1
Mar 29, 2003 07:14 AM
JurakS
Aug 20, 2002 07:46 PM
