B16a1 BUT it will be OBD1 !!!
Old Dec 25, 2002 | 09:06 PM
mz3bo's Avatar
Default B16a1 BUT it will be OBD1 !!!
Hi, i've read a few post on engine, ecu ,distributors and found out everything seems to work together. My question is: I f I have a B16a1 (AKA OBD0), can I put a OBD1 distributor on it and make it a b16a1 OBD1 to be installed into a 92-95 civic using a p28 ecu? Is that process as easy as plug and play, can we do that kind of transplant? Also, wich distributor can fit a b16a1 ? Would the integra 92-96 Gs/ls BUT using a GSr ECU OBD1 would fit... this said, is the GSR distributor and Ls/gs the same, with same years specs?
Cheers
Old Dec 25, 2002 | 11:18 PM
mmuller's Avatar
Mad Scientist
Default Re: B16a1 BUT it will be OBD1 !!! (mz3bo)
any vtec dist. will fit, and the ls distr. fits but you have to chop one of the legs off(only one bolt will hold it),a cooland temp sensor with housing from a 92up, then wire harness and alternator.
Old Dec 25, 2002 | 11:44 PM
3rdGteg's Avatar
Default Re: B16a1 BUT it will be OBD1 !!! (mmuller)
So would the single cam vtec distributor from the 92-95 civic ex/si work on the b16a1 without any problem?
Old Dec 26, 2002 | 10:04 AM
Flexmyrex's Avatar
Default Re: B16a1 BUT it will be OBD1 !!! (3rdGteg)
i dont know about the single cam vtec, but my sohc distributor off the crx didnt work on the ls, but the internals were all the same, just swaped it all in.
Old Dec 27, 2002 | 06:54 PM
salbaje's Avatar
if you want use obd1 intake manifold,dist. alt. ecu, etc. my friend has a jdm b16 in his 95 coupe
Old Dec 27, 2002 | 08:22 PM
mmuller's Avatar
Mad Scientist
Default Re: B16a1 BUT it will be OBD1 !!! (salbaje)
yes, the sohc distr. wont work but as flexmyREX said you can swap the internals, you can use any dohc vtec or ls distr.
peace
7rrivera7
May 14, 2014 03:25 AM
dfanatic86
Mar 5, 2014 05:23 AM
AzCRX
Apr 15, 2007 04:23 PM
EGHatchy
Jul 15, 2002 09:49 PM
