... b18c1 with 83mm bore and ls crank - 2.0
... i know that a gsr with an 83mm bore is about 1.9 liters... so i was wondering if the ls crank would push it to 2.0... just curious...
[edit] : also, can someone tell me the exact displacement a gsr block will have with an 83mm, 84mm, and 84.5 bore... thanks...
[Modified by 1.8T_EG, 5:03 PM 12/25/2002]
A b18c with 83mm pistons will get you close to 1.9 still a 1.8. A b18c with ls rods and ls crank will get you to a 1.9, and a b18c with 1s crank and rods with 84mm pistons will be identical to b20 I believe 1975cc's? pretty close to 2.0 . 85 mm would get it almost to 2.0 I dont know the exact specs, some people on here that actually passed ther math class can figure out the exact displacement, I know that what I said is the ball park. Jason
You could use a 1991 prelude crank to push it to 2.05 liters, but you probably don't want to do that. 95mm x 83mm is stock in the b21a. I have a b21a crank if you want to buy one.
I am pretty sure the b18a,b,c and b20b,z have the same deck heights. The B16 is the one with the shorter deck height. You can put an ls crank in a b18c block if you use ls rods. You will essentially have an ls motor with oil squiters and a girdle.
It will fit believe me, and the ls and gsr deck heights are the same
By my calc's, these are the displacements you would get.
83mm Bore x 87.2mm Stroke (GSR) = 1.887L
83mm Bore x 89.0mm Stroke (LS) = 1.926L
83.0mm Bore x 87.2mm Stroke (GSR) = 1.887L
83.5mm Bore x 87.2mm Stroke (GSR) = 1.910L
84.0mm Bore x 87.2mm Stroke (GSR) = 1.933L
84.5mm Bore x 87.2mm Stroke (GSR) = 1.956L
85.0mm Bore x 87.2mm Stroke (GSR) = 1.979L
83.0mm Bore x 89.0mm Stroke (LS) = 1.926L
83.5mm Bore x 89.0mm Stroke (LS) = 1.949L
84.0mm Bore x 89.0mm Stroke (LS) = 1.973L
84.5mm Bore x 89.0mm Stroke (LS) = 1.996L
85.0mm Bore x 89.0mm Stroke (LS) = 2.020L
Rice Is Best
13
Sep 2, 2010 02:10 PM
euclid
22
May 11, 2004 08:15 PM
