How much HP do you guys think i will make?
Just a question and curious as to what you guys think i might hit. Im not even sure im just rebuilding from a complete N/A build up. This turbo project will be complete in about 2 weeks. Well here is my setup tell me what you think i will hit
LS/VTEC turbo
Garrett T3/T04E 50 trim turbo
Inline pro manifold
Tial 35mm wastegate
Tial blow off valve
Custom 2.5" piping
PWR intercooler
b16a head ported polished
3 angle valve job
GS-R cams
Skunk 2 springs/retainers
ITR intake manifold
Hondata intake gasket
ARP head studs
Wiseco 9.0:1 pistons
Eagle rods
B18A block sleeved .20 over
Z10 crank girdle
Thermal 3" exhaust
3" high flow cat
AEM enigine managemnet system
I may have forgoten something so let me know if i did.
Im hopeing for close to 400whp after tuning with the AEM!
thanks,
gen2teg
[Modified by GEN2TEG, 2:47 AM 12/25/2002]
LS/VTEC turbo
Inline pro manifold
Tial 35mm wastegate
Tial blow off valve
Custom 2.5" piping
PWR intercooler
3 angle valve job
GS-R cams
ITR intake manifold
ARP head studs
Eagle rods
Z10 crank girdle
Thermal 3" exhaust
3" high flow cat
thanks,
gen2teg
400hp
GSR cams
GSR cams
What cas would you recommend over these ones?
thanks,
gen2teg
[Modified by GEN2TEG, 2:53 AM 12/25/2002]
What size injectors are you running? That setup should net 400whp w/ the right fueling.
thanks,
gen2teg
ive seen much data on gsr cams being a nice addition with boost....but maybe he knows something i dont
gsr cams
gsr cams
u should upgrade to a tial 40mm , for higher boost.
I've heard people say that because of my turbo's trim size it may "run short of breath" so i figure that would work (35mm)
Alright guys. sorry for doing this
to gsr cams. I Didn't think it would make a big comotion. Just thought since he is dumping alot of money in the motor why not get aftermarket performance camshaft. Thats all.
if you are gonna sleeve get, get some 83mm or 84mm sleeves...
I also inquired and was told i may have to modify the head. I have yet to decide on what size sleeve im going with, i think im decided on 83mm.
Go with 83. Then if (I hope it doens't happen to you) you have to rebuild for some reason, you still have another 1 mm to bore out your sleeves.
I think thats what im going to do i was leaning towards the 83mm side.
It looks like a pretty solid build up, are you planning on upgrading your fuel lines? What fuel pump are you using? You should be close to 400whp, the only thing holding you back is the 50 trim t3/t4. What are all the specs on the turbo? Most 50 trims ive seen flow around the 330-350 mark, if you had the 60-1 i would say you'd put out well over 400whp.
after you put down about 300-350whp you want to run a larger sized fuel line, -6an is a good size to use but i chose -8an so i didnt have anything to worry about with putting down over 400 to the wheel.
Topdawgg
Oct 10, 2006 09:36 AM
