Engine swap completed, assitance needed with rpm's!!!!
Old Dec 24, 2002 | 02:00 PM
Tony Starks's Avatar
Default Engine swap completed, assitance needed with rpm's!!!!
My engine blew a few days ago, so I went from a 99 y7 to a 00 y8. Swap is complete and I only threw two codes due to lack of a secondary o2 sensor. When I started the car, it shot up to 4,000 rpm and stayed there. Does anyone know why? Please help, its xmas eve and I must have my car running properly for tomorrow. TIA!!!!!!!
Old Dec 24, 2002 | 02:25 PM
CzanSOHC's Avatar
Default Re: Engine swap completed, assitance needed with rpm's!!!! (Tony Starks)
Check your throttle linkage.
Old Dec 24, 2002 | 02:28 PM
Default Re: Engine swap completed, assitance needed with rpm's!!!! (CzanSOHC)
yup, that was my first idea. thanks for the help though. any other thoughts?
Old Dec 24, 2002 | 02:34 PM
ninesecrx's Avatar
big vacum leak...I will almost gurentee it.
Old Dec 24, 2002 | 03:20 PM
Default Re: Engine swap completed, assitance needed with rpm's!!!! (ninesecrx)
vac leak? i'm gonna go check it out right now. thanks.
Old Dec 24, 2002 | 04:28 PM
Well, I've got the high idle calmed down. Now I have another problem. When I hit the gas or pull the throttle cable, the engine hesitates, sometimes even wants to stall out, before raising in RPM's. Any suggestions??? Please help!!!!
EDIT: Would having only one O2 sensor installed be causing this problem?
[Modified by Tony Starks, 1:40 AM 12/25/2002]
Old Dec 24, 2002 | 05:40 PM
Idle problem fixed. However, it flutters back and forth from 1K to 2K, so I corrected one problem just to run into another one. Ran another diagnostic after taking it around the block and threw these codes P0113- Intake Air Temperature Circuit High Input and P0505- Idle Control System Malfunction. Any ideas on how to fix these???? TIA and Happy Holidays.
Old Dec 24, 2002 | 05:44 PM
johnzm's Avatar
umm, im no pro to OBD anyhting, but see if the plugs can be reversed
Old Dec 24, 2002 | 05:47 PM
boostaholic's Avatar
Default Re: Engine swap completed, assitance needed with rpm's!!!! (johnzm)
Try swapping the IAT sensor from another manifold and see if that fixes that problem, could be just a bum sensor. For the IAC (idle air control) valve, take it off and clean it out the mesh screen with some brake cleaner. HTH.
Old Dec 24, 2002 | 07:29 PM
I know where the one plug is, behind the intake manifold, but where is the other? The two look exactly alike and I think they are reversed too.
Old Dec 24, 2002 | 07:35 PM
CzanSOHC's Avatar
sounds like a vaccum leak w/ the idel....and make sure all the sensor are correct.
CzanSOHC's Avatar
What ECU are you running?
Old Dec 24, 2002 | 11:42 PM
Both the IAT and IACV sensors are on the intake manifold. The IAT is going to be on one of the runners, and the IACV is on the back of the manifold near the throttle body with 2 coolant lines running off it. It's quite possible that you just got those two sensor clips switched around.
Old Dec 26, 2002 | 09:25 AM
the 00 y8 ecu, p2e
Old Dec 26, 2002 | 11:34 AM
Car is fixed. Swapped out the throttle body. My A/F gauge doesn't work though. I'll have to rewire that Thanks for the help everyone.
JDM-FREAK
May 11, 2013 02:15 PM
13btJim
Mar 10, 2010 07:06 AM
JDMhon
Nov 19, 2006 09:16 PM
b18civic
Apr 22, 2002 07:20 PM
