FMU install
Old Dec 23, 2002 | 07:28 PM
dpreludesi's Avatar
Default FMU install
I just installed the fmax kit. I just received my FMU, and the fuel pump is on the way. I was wondering if I can go ahead and install the fmu or if i have to wait for the fuel pump(inline) to install it. THanks.
Old Dec 23, 2002 | 07:32 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: FMU install (dpreludesi)
FMU? are you talking the litte blue FMU thing? or the black computer?
Old Dec 23, 2002 | 07:40 PM
dpreludesi's Avatar
Default Re: FMU install (Boosted97Lude)
the blue vortech fmu, with a 12;1 ratio. Looks like a circle with a square mounting bracket.
Old Dec 23, 2002 | 07:50 PM
Boostless97Lude
Guest
Posts: n/a
yeah... um, why do you have one of those if you bought the F-Max kit, they use a MF2 piggyback fuel management
Old Dec 23, 2002 | 07:59 PM
dpreludesi's Avatar
Well I bought the kit used. I asked the guy about his set up. He said the mf2 wasn't working right in his car. He didn't use it and ghetto rigged a better fuel pump that he had laying around his shop for a civic. I also didn't like the idea of adding more fuel with the 2 440's the fmax kit came with. Eventually after i get some pistons, and lower the compression i am going to put a walbro intank fuel pump in. Since I am only running 6psi i didn't want to run too rich with the intank. Do you think the mf2 is better than the current route i am going. I already have the fmu and the holley inline is on the way. I'm pretty new to the whole turbo scene. Any help you give me is greatly appreciated.
Old Dec 23, 2002 | 08:02 PM
Boostless97Lude
Guest
Posts: n/a
first off, don't use an inline, second, don't use an inline. oh, and i forgot, don't use an inline. the FMU will be OK, and you can goahead and install it without the turbo if you want, b/c those things a boost dependent,and won't alter your fuel pressure until they read boost
Old Dec 23, 2002 | 08:09 PM
dpreludesi's Avatar
The turbo is already installed. Thats why i was asking if it was ok to install the fmu. Why should i not use the inline? Some people tell me to use it and others tell me not to. I am afraid to use the intank because i don't want to run too rich. If you think that is the better idea, thats cool. I know the fmu works with boost, but i wasn't completely sure how it does and if was ok to run without either an inline, or a intank.
Old Dec 24, 2002 | 05:01 AM
Boostless97Lude
Guest
Posts: n/a
you won't run to rich, you fuel pump does not regualte your fuel pressure, your FMU and FPR do.... but it will be ok to install the FMU without the pump. i hope you haven't been driving the car with a turbo but without the FMU
Old Dec 24, 2002 | 08:56 AM
BoostedH23a1's Avatar
man that is the stupidest thing u have ever said..
u HAVE TO RUN THE INLINE.. i have my inline pump on a swich and if i dont turn it on i run out of fuel at 4 psi. it bucks like crazy
the stock intank fuel pump cant provide enough pressure to supply the 12:1 fmu. at 7psi heres bascily the break down..
stock fuel pressure say 45ish
7 psi boost * 12 (12 beging 12:1 a/f ratio)
7*12=84
84+45(base fuel pressure)=129
129 would be your fuel pressure in your fuel rail.. no way a stock fuel pump can take that.
Old Dec 24, 2002 | 10:27 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: FMU install (BoostedH23a1)
no, no , no, he needs an intank
Old Dec 24, 2002 | 10:01 PM
dpreludesi's Avatar
I am going to buy an intank after i build the motor a little and can push more boost. This is only temporary so i have enough fuel for 6 psi. Wouldn't that be ok? What is the disadvantage of the inline anyways? I have been told not to use it, but nobody has told me why yet. Thanks for all the input everybody.
lucidvtec
Jun 28, 2005 12:38 PM
deca
May 3, 2005 12:15 PM
bcause
May 24, 2002 02:03 PM
turboex
Apr 6, 2002 04:59 PM
