question about shaving side moldings
Old Dec 23, 2002 | 11:18 AM
GsR HtCh's Avatar
Default question about shaving side moldings
i am getting a new paint job real soon and wanted to get my side moldings shaved. i dont want them filled in but i want the molding off and the holes filled in. is there a good way to do this. has anyone done it themselves? i brought it to my friends body shop and they said that its tough cuz you slam the doors and it might break off. Ive seen it done plenty of times on this board. i did a search and nothing came up about taking the moldings out and filling in the holes. can anyone help.
Old Dec 23, 2002 | 12:15 PM
GsR HtCh's Avatar
Default Re: question about shaving side moldings (98civichtchback)
Old Dec 23, 2002 | 12:36 PM
RenoRacing's Avatar
the most common way is to weld over the holes from the backside and then just a little duramix and some sanding.
Old Dec 23, 2002 | 12:37 PM
GsR HtCh's Avatar
Default Re: question about shaving side moldings (HavokRacing)
i heard that the welding will warp the door.
Old Dec 23, 2002 | 10:06 PM
GsR HtCh's Avatar
anyone else
Old Dec 23, 2002 | 10:39 PM
.Beaver's Avatar
Bloody Beaver
I don't know how he did it, but my friend has 2 CRX's with shaved moldings and both are daily driven and get lots of door slammings, and so far no problems.
Old Dec 24, 2002 | 11:17 PM
GsR HtCh's Avatar
Default Re: question about shaving side moldings (93 MR EJ1)
are they shaved completely or are just the holes filled in.
Old Dec 24, 2002 | 11:32 PM
JSJ EG6's Avatar
i dont know how they did it to my accord. but the weld something and they use fiber glass not bondo.
Old Dec 25, 2002 | 12:23 AM
EKFerioHawaii's Avatar
Default Re: question about shaving side moldings (TEAM JSJ)
Here's my .02 cents about shaving moldings. If possible, don't do it. But if you want to remove the moldings then its all right in my book. I'm a part time automotive body man.
There's this adhesive much like jb weld and epoxy. It's called "Fusor". Found at any hardcore automotive body shop; in tubes which have to be mixed together.
It's stronger than most welds. My friends body shop did a "Fusor" test. We seam welded a fairly thick gauge of sheet metal and "Fusored" another sheet to it. A few taps with a sledge hammer on both ends, and the weld broke before the adhered side. We use this product to fill in moldings, handles, and anything else which welding could damage.
I've done DC moldings before. Moldings out, there are the holes left over. I just "Fusored" a few pieces of aluminum sheet metal from the inside and resined the rest from the out side. The first car I did was a second gen DA, which I molded his handles using Fusor. Given the intense abuse of car handles, you would think it would've cracked, but it's been 1.5 years with no complaints.
Well, hope this helps.
Old Dec 25, 2002 | 09:47 AM
.ian.'s Avatar
Default Re: question about shaving side moldings (EKFerioHawaii)
Bondo fills em right up! Those thing are hard as rock when it dries, so I doubt they will fall off if you slam the door.
Old Dec 25, 2002 | 08:56 PM
GARBhatch.'s Avatar
Default Re: question about shaving side moldings (phi0)
riiiiiiiite.... bondo.... did you read N E of the other posts about this?? i guess theres one in every thread... thats interesting about the fusor i never heard about that.. just mixed reviews about welding and mostly negative on body fillers.. good insite man
Old Dec 25, 2002 | 09:05 PM
tnbigdawg's Avatar
Default Re: question about shaving side moldings (98Hatch00)
there's also a product called DURAMIX, but you need a special gun for it. and the DURAMIX tube is about $30-40. Pretty expensive. how much is that FUSOR?
Old Dec 26, 2002 | 04:48 AM
Default Re: question about shaving side moldings (tnbigdawg)
Actually there about the same price. I couldn't get the name of the other product that does the same thing as FUSOR until you said DURAMIX. FUSOR and DURAMIX are similar products. A rented/bought gun is also needed for Fusor application.
About $35 here in hawaii @ napa (waipahu)
503_EF9
Paint and Body
Nov 12, 2007 06:16 PM
Eagle16nam
Feb 5, 2006 09:47 PM
b16greenmachine
Jan 9, 2006 11:38 PM
GsR HtCh
Dec 23, 2002 11:27 AM
skunk2 teg
Jan 22, 2002 09:05 PM
