please help can a vafc burn out the circuit for your vtec oil pressure???
Old Dec 23, 2002 | 06:47 AM
topsekret's Avatar
Default please help can a vafc burn out the circuit for your vtec oil pressure???
give me any info u have thanks
Old Dec 23, 2002 | 07:16 AM
JD_B18CDX's Avatar
Default Re: please help can a vafc burn out the circuit for your vtec oil pressure??? (b18vtec)
Chance are not.
Old Dec 23, 2002 | 01:47 PM
rioninja's Avatar
Let me guess, throwing a code?
Let me also guess that you didnt hook up the VTM signal wire from the vafc.
Old Dec 23, 2002 | 10:26 PM
topsekret's Avatar
Default Re: please help can a vafc burn out the circuit for your vtec oil pressure??? (RioNinja)
ok heres the deal i had the vafc hooked up right well the person wired the map sensor wires to the vtec oil pressure(vtm) wire and well then i realized it it threw the code for vtec oil pressure and now i corrected the problem put back to stock and still the code kicks on i cleared the ecu and everything but it still seems to come on checked the wires and seem to be good any suggestions???
Old Dec 24, 2002 | 12:04 PM
topsekret's Avatar
i checked with another ecu and it still threw code 22 please help
Old Dec 24, 2002 | 01:22 PM
JD_B18CDX's Avatar
Make sure there is 60 psi of oil presure @ 5000 rpms. You might not have enough presure to trigger the switch. If you are sure you have good oil presure,
Try this.
1. Check for continuity on the 2 terminals of the VTEC presure switch. If there is no continuity, replace that bitch.
If there is continuity then do ......
Turn iginition on.
Measure voltage between (+) bue/black wire and ground on engine harness. (since yours is an LS Vtec, the wire that supplies voltage to vtec oil presure switch)
If there is no power, you check wiring. There is probably a break somewhere.
IF wiring is ok, check for voltage on terminal D6(+) and D22(-) on the ECU. There should be 12V @ 6000 rpm.
Otherwise, replace ECU.
[Modified by JD_B18CDX, 5:25 PM 12/24/2002]
egcoupeSI
Apr 17, 2008 08:47 AM
spoolineh2
Jun 14, 2004 01:38 PM
1insaneR
May 10, 2004 10:19 PM
92b16vx
Oct 25, 2003 02:07 AM
96tegsr
Aug 12, 2003 08:53 AM
