Got a used turbo, want to clean it up...
Old Dec 22, 2002 | 09:06 PM
JalopySiR's Avatar
Default Got a used turbo, want to clean it up...
Is there anything I should NOT do? i.e. it will screw up the turbo. Thanks for any help!
Old Dec 22, 2002 | 09:23 PM
Technician's Avatar
Default Re: Got a used turbo, want to clean it up... (JalopySiR)
I would say that you should not try to rebuild it you're self
It's worth the money to have someone that works on turbos all day
to clean it up. however you can check the shaft run out or side play with a
dial indicator. with a mechanics touch try to move the turbine up and down and side to side. a good turbo will have a small amount of play, a bad one will have more than a small amount. the correct way would be to measure the play
in one thousandths of a inch and compare it to O.E.M specs. like .012" ? also you can look for cracks on the turbine housing, and evidence of oil in the compressor housing. also the compressor blade, the edges will be chiped depending on how used it is or if someone took the air filter out. yeah thats what i'm talking about
spool it up and use it to chip up twigs and branches, or a high pitched garbage disposal... AH AH AR COOL.
later main
Old Dec 23, 2002 | 09:25 AM
JalopySiR's Avatar
Default Re: Got a used turbo, want to clean it up... (Technician)
I won't be doing anything to in depth. I just want to clean, paint, and clock it. It seems to be in fairly good condition. Anything else?
Old Dec 23, 2002 | 12:44 PM
BudaKai's Avatar
Kerosene - just don't blow yourself up.
Degreaser - "WIDE OPEN" area's only...
Wire wheel - if yout take the housing off first.
You can polish it while you have the housing off, if you take it off.
Old Apr 23, 2003 | 10:45 AM
kHoA DoGG's Avatar
Default Re: Got a used turbo, want to clean it up... (BudaKai)
could you take off the housing and put it together w/o too much difficulty and messing anything up?
turboteg2nv
May 24, 2015 12:38 PM
curt801
Feb 8, 2007 06:18 PM
SPOOLINmatt
Jan 28, 2005 06:48 PM
FuzzyGreen
Sep 3, 2003 08:23 AM
Veil_Side_
Jan 29, 2003 12:39 PM
