leaking oil, not much.. but.. pictures inside
Old Dec 22, 2002 | 09:54 AM
geminis2k's Avatar
Default leaking oil, not much.. but.. pictures inside
motor has perfect compresson, no coolant in oil or vice versa.. so please explain this ..
Old Dec 22, 2002 | 10:02 AM
LostGsr's Avatar
Default Re: leaking oil, not much.. but.. pictures inside (Alex)
Leaking Cam seal. Very common in integra. Just replace it with another oem one.
Old Dec 22, 2002 | 10:05 AM
integranator's Avatar
Default Re: leaking oil, not much.. but.. pictures inside (LostGsr)
yesiree bob. Very common on vtec motors. I say, if u got the money replace it with an aftermarket one.
Old Dec 22, 2002 | 10:34 AM
rodimus's Avatar
Default Re: leaking oil, not much.. but.. pictures inside (integranator)
i would replace all the seals while yer at it...
Old Dec 22, 2002 | 10:37 AM
integra-modder's Avatar
Old Dec 22, 2002 | 10:54 AM
neo1z's Avatar
Default Re: leaking oil, not much.. but.. pictures inside (integra-modder)
as in STR cam seals...they are very good
Old Dec 22, 2002 | 10:56 AM
au-gsr's Avatar
Default Re: leaking oil, not much.. but.. pictures inside (neo1z)
but they wear out just as fast as an oem seal- anyway acure saw this as a problem and addressed the issue by producing a better oem part.
Old Dec 22, 2002 | 03:05 PM
IntEGNYC's Avatar
Default Re: leaking oil, not much.. but.. pictures inside (au-gsr)
I replaced mine a few months ago. Its common.
Old Dec 22, 2002 | 03:13 PM
geminis2k's Avatar
Default Re: leaking oil, not much.. but.. pictures inside (IntEGNYC)
Well, I guess that is some of a relief - thanks. Exactly how hard is it to change the cam seal and could I damage anything by driving the car like that in the meantime?
Old Dec 22, 2002 | 03:39 PM
au-gsr's Avatar
you have to pull off the head cover other than that concult a mnual. as far as driving yourcar with it like that - I did for over 5 years and jsut waited till i got my timing belt replaced, the oil that leaked out was insignificant and i barely had to refill the oil because of it. i just wiped themess up as it appeared.
ILS_09
Nov 5, 2009 01:58 PM
nonvtec92
Nov 1, 2009 01:28 PM
vinuneuro
Aug 6, 2008 05:16 PM
Walterronny
Apr 16, 2006 05:16 PM
UNDER PRESSURE
Nov 18, 2003 10:19 PM
