D-Series Manifold for KKK K26 Turbo
I haven't measured it, but I have a K26 at work and the flange looks REMARKABLY close to a T3 flange... you may be able to just have a standard T3/T4 flanged manifold modified slightly to work. Worth a shot anyway.
haha no ****.! i got the same turbo! and looking for a mani also.
the bolt holes are 4cm center to center and 8cm center to center
can someone measure a T3 flange for us
I got mine from a wrecked porsche 944 in a junk yard when I went on a salvaging quest for window motors for school (don't ask) I saw the porsche and almost everything had been pulled but the exhaust manifold/turbo. What sucks is I also need to get a fuel management unit and injectors for this and I'm not sure what ones to use.
So if anyone can help me out there
yep. i got mine for 30$ at the junkyard.
pretty big.
i gotta go track down some oil lines and fittings and a home made boost controller. ill keep up on this post
pretty big.
Hi all, is the K26 turbo pretty good? I found one at the local yard. It spins very smooth, better the than my Mitsubishi TD04. Should I keep my TD04 turbo or go w/ K26?
i'm gonna be doing my first turbo setup on my friends EF and he bought of my buddie the KKK turbo that was on a 1.8L turbo golf.
The turbo looks really good.
The bolt holes are the same as a t3 flange. The problem with most of those turbos is the recessed area that is on the turbo flange. I did a custom kit on an Eclipse and i had to weld it up flat and then took it to a machine shop to be resurfaced..
yep
i got a turbo map here for the k26 and i mapped out how my motor would spool it.
it wont be fast but the high end looks promising.
3000 rpm itll spool.
i wish i had a scanner i have it all plotted out
also. the one out of the posrche has a differant exhaust side trim (trim right?) on the porsche it will spool more around 4000 rpm. but it pushes boost great.
[Modified by shortyz, 1:25 PM 12/24/2002]
The T3 flange is 86mm x 45 mm between the boltholes.
The K26 turbos also have the same depression. I am very familiar with the volvo ones and you are correct. This turbo also had the same flange and it was a K26. Either way jsut weld it up, resurface, and it will fit a t3 perfectly.
Boostinb20!
Dec 26, 2008 05:37 AM
TsunamiZC
Nov 12, 2008 06:23 PM
rollinlowinthecivic
Jun 8, 2008 12:16 PM
