Help with manifold
Old Mar 31, 2009 | 06:36 PM
sixgunsound's Avatar
Default Help with manifold
Hey everyone I'm pretty new to turbos and everything that go with it so try to go easy on me. Im looking at buying a turbo like the one below and I'm trying to find a manifold for for it. Thing is every manifold I find dosnt have the proper flange on it. The turbine has the little divider in it there instead of it being open. I know theres like T3, T4 v band and all that, does that refer to that area? If so, what is this one called? Sorry if its a dumb question but I'm kinda just getting the hang of things.
Old Apr 1, 2009 | 03:08 AM
Default Re: Help with manifold
Anybody?
Old Apr 1, 2009 | 06:00 AM
Sir2egk's Avatar
twin scroll
Old Apr 1, 2009 | 06:07 AM
dephtone's Avatar
It's a divided t3 flange. Just because there is a divder in the flange doesn't make it a twin scroll. Iv seen people use regular t3 flanged manifolds and run a divided housing and it's fine. If you want to use the turbo with the divided housing you will have to run a divded housing manifold which usually is at extra cost for manifolds.
OP is there a particular reason why you chose this turbo? What are your goals? What motor are you running?
Old Apr 1, 2009 | 02:16 PM
TheShodan's Avatar
Moderator
You also want to be careful and measure the outer diameter of the V-band of the turbine housing and make sure that a standard 3" flange will work with your downpipe. If not, you'll need to find out what downpipe flange is used so that the two will mate up.
Old Apr 1, 2009 | 02:24 PM
Well i chose this one because the guy is selling it for $250 which i think is pretty decent. I'm trying to put together my own kit, I'm not lookin to push more than 10 psi.
Silvertc
Jan 26, 2009 05:00 PM
Boostinb20!
Dec 26, 2008 05:37 AM
rollinlowinthecivic
Jun 8, 2008 12:16 PM
kenbdSi
Sep 12, 2006 04:50 PM
00BoostedGSR
Jun 11, 2006 03:32 PM
