Cam and Intake Manifold swap.
I should be getting my Z6 IM any day now, and i want to swap my crx si cam and AEM gear in at the same time, now some more things i wanna get, let me know if its a good idea.
Valve cover gasket, IM gasket, plugs, wires, rotor + cap, fuel filter?, what else should i be thinking about replacing while its apart? Timing belt? Thanks.
Oh ya my setup, D15B7, Aem intake. More to come.
dont know about the manifold but i have some advice
why are you spending money on a cam gear?
you can do the same thing by rotating the distributor.
the reason cam gears are good for DOHC motors is because you can dialout overlap, you cant do that on a SOHC motor.
dont waste the money
i need the cam gear to tune the cam, got it for $50 cdn anyway. The Crx Si cam is 1/2 a tooth off, so ill either be 4.75 degrees advanced or retarded. And your cam timing controls where the power is in the RPM range.
B_1_8_hatch
Mar 17, 2003 05:53 PM
Slow Rocket
Feb 25, 2002 05:45 PM
