to those that have installed motor mount inserts.
Not necessary. And the tranny mount is a pain to get to, you might have to unbolt it to get the inserts in and then retighten the bolts to spec.
so you can install the motor mount inserts with "basic" hand tools?
What are some pros and cons to having motor mount inserts?
-Ryan
-Ryan
-Ryan
-Ryan
Ratchet, couple feet of extensions, swivel socket are pretty much it.
damn i dont know how you guys did it! i had the manifold off and i still couldnt take it out. i had to unbolt the climate control valve and unbolt the back engine brace!@! and now my climate control is fuxed@@@@!@!
[Modified by gsrstyle, 1:00 AM 12/21/2002]
yea fronts were easy the rear was alot of swearing and many many many extions and swivels and still fought with it .
The rear one is the spawn of Satan. When I did mine, I ended up unbolting most of the engine and raising/lowering it a few inches. And just when you think you're finished by getting it out ... HA! Getting it back in with the added size from the inserts is worse!
Yes, basic hand tools are all that it calls for.
What exactly will the aftermarket mounts do for you in the long run though?
Mike
01GSRcpe
Mike
01GSRcpe
Thundersquid
Oct 23, 2003 10:43 PM
ill phil
Jan 13, 2003 10:15 PM
