Tips on insert mount install
anything anyone want to tell me before i tackle the job. I ordered the Energy Suspension Motor mount insert kit. 3 pcs.. 98 Civic DX
Re: Tips on insert mount install (shane Z)
for the front two...pull back the fender liner and ull have easy access to the bolts that hold the mount to the frame...then after you pull those loose take off two of the tranny mounts and loosen the third. u should be able to swivel the mount down and chance the passenger side off easy. for the driver side to the exact same but loosen the motor mount (17mm nuts) dont fully take them off just loosen them and it will allow you to pull the mount down. for the rear jack up the car and and unbolt the mount...then using a jack with a piece of wood on it apply some pressure to the motor and it should rock back to allow you to barely squeeze it out. putting together is the same as taking apart. good luck and take your time the rear one is frustrating as hell
Blue-Civic-Hybrid
01-25-2005 05:44 PM
Thundersquid
10-23-2003 10:43 PM
