Stainless steal oil feed line how close can it run the manifold.
Hey all I recently killed my turbo buy not having a “good” oil flow though my turbo, it was to much on a angle, and yeah caused problems, but for me to run it true straight up and down I have to run the oil send line touching the exhaust manifold (this is a max rev manifold) does anyone know if stainless steal braded hosing can withstand high temp.. or am I playing with fire running the oil send line so close to the manifold.
Also what kind of angels do you guys have your oil feed entering / leaving the turbo.. because I was told not to have it more than 4 degrees, if possible !
Regards James
Regards James
You shouldn't have the oil feed line against the manifold, the hose is rubber underneath and is not that resistant to heat. I haven't heard about having to run the feed line straight up and down. It is fed by the engines pressure. You may be confusing your friends advice with the return line. You should have your return line as straight down from the turbo as you can. The return line relies on gravity to allow the oil to leave the turbo. You want to make sure both your feed and return lines are not kinked.
JGTW
Feb 15, 2019 02:53 PM
