Shortblock. Question !
Old Dec 19, 2002 | 11:49 PM
Ex-ITR5874's Avatar
Default Shortblock. Question !
I`m looking for a new engine for my ITR.
Now, I received an offer:
A b18c1 block fit with Type R pistons and a Type R head...
So my question:
What is the difference between a bare b18c1 block and a bare b18c5 block (meaning without pistons and rods...) ?
Old Dec 19, 2002 | 11:52 PM
IN VTEC's Avatar
Default Re: Shortblock. Question ! (ITR1858)
The crankshaft.
The stampings on the block and crankshaft for main bore and crank journal sizes.
Engine code stamping.
Old Dec 20, 2002 | 01:17 AM
EK MONEY's Avatar
Default Re: Shortblock. Question ! (IN VTEC)
for sure. thats what it is.
Old Dec 20, 2002 | 04:45 AM
9KRacer's Avatar
New User
Default Re: Shortblock. Question ! (Peagreenhatch)
Old Dec 20, 2002 | 05:18 AM
RagingAngel's Avatar
Default Re: Shortblock. Question ! (9KRacer)
The rods are different too....
ITR rods + PR3 pistons will not fit
GS-R rods + P73 pistons will not fit unless the small end of the rod or the piston is shaved.
Old Dec 20, 2002 | 06:01 AM
b19coupe's Avatar
Default Re: Shortblock. Question ! (RagingAngel)
P73 pistons will fit on GSR rods.
Old Dec 20, 2002 | 12:23 PM
Ex-ITR5874's Avatar
Default Re: Shortblock. Question ! (b19coupe)
Okay okay, thanks
So what does that mean to me..? Note, we have ONLY the Type R in Germany. I am not experienced with the other engines. So your help is needed (thanks again)
How can a b18c1 block be a replacement for a b18c5 ?
Using a Type R crankshaft, Type R rods and pistons ?
Or should I better wait until I find a b18c5 block ?
Sven
Old Dec 20, 2002 | 01:10 PM
b19coupe's Avatar
Use the B18C1 block, you will be fine. All of the parts are interchangeable between the B18C5 and C1.
Old Dec 20, 2002 | 05:42 PM
ITR#132's Avatar
You meant LS/RS/CRV rods
Old Dec 20, 2002 | 06:34 PM
FSTASNTZ's Avatar
Default Re: Shortblock. Question ! (ITR#132)
The bare blocks should be idnetical in dimmensions, just a different stamp for the block code. If it makes you feel any better, I am running a B18C1 in my ITR, replaced my B18C5 with bad rings. Is the B18C1 stock, not exactly...
Jason
eg4life1202
10
Dec 1, 2018 11:05 PM
gian_ed7b16a1
May 23, 2017 09:31 AM
dragEF8
Jun 16, 2004 11:48 AM
phattycrx90
Mar 1, 2003 02:13 PM
Jubba
May 7, 2002 01:31 PM
