Check my fitting... Just makin sure.
Old Dec 19, 2002 | 01:52 PM
DIY_Racing's Avatar
Default Check my fitting... Just makin sure.
Ok, im not welding my oil pan. Instead im just putting two fittings together, some hondabond and these two fittings... this is for the return line. Are these two fittings the one i need??? Oh, -10 for return line right??
Is thatcorrect????
[Modified by DIY_Racing, 10:52 PM 12/19/2002]
[Modified by DIY_Racing, 11:32 PM 12/19/2002]
Old Dec 19, 2002 | 02:33 PM
DIY_Racing's Avatar
Default Re: Check my fitting... Just makin sure. (DIY_Racing)
t
Old Dec 19, 2002 | 02:37 PM
project dc2's Avatar
Is thatcorrect????
yep i suggest soem nylon washers while your at it .. be sure you have two nuts .. so you can " lock:" them together
Old Dec 19, 2002 | 02:48 PM
JM Performance's Avatar
Default Re: Check my fitting... Just makin sure. (project dc2)
yep....you always wanna make sure you have two nuts.
Old Dec 19, 2002 | 02:51 PM
DIRep972's Avatar
Smarter than you
Default Re: Check my fitting... Just makin sure. (00SilverLS)
holy chit! its 00silverLS. where have u been?
Old Dec 19, 2002 | 02:56 PM
AbaZ's Avatar
the hole on that fitting looks a bit on the small side (but then again it could just be the pic, -10 is pretty decently sized.). You want the oil return to have a nice free clear path to the pan with no type of restrictons, especially since the oil return is gravity fed..
Just be careful.
Jeff
Old Dec 19, 2002 | 03:22 PM
PM-Performance's Avatar
Default Re: Check my fitting... Just makin sure. (AbaZ)
watch oput man , i know people doing it like that that ended up getitng it wleded becuase it was leaking .
what could it cost 10$ to get wleded
Old Dec 19, 2002 | 03:36 PM
spooled b16's Avatar
Default Re: Check my fitting... Just makin sure. (itr206)
yep getting the return pipe welded to the pan is the only way
Sonny's Avatar
I'm using the -10 AN bulkhead setup as well. Where do you guys find Nylon washers that large? I was thinking of maybe using copper or aluminum oil drain plug washers instead. Any thoughts?
Thanks,
Sonny
Old Dec 19, 2002 | 03:55 PM
Default Re: Check my fitting... Just makin sure. (Sonny)
oil drain plug washers come in nylon also .. i have soem at my shop .. its in my universal oil drain plug set .. and theres nylon ones int here so im sure you can get them at any parts store ..
importdude2000
Jun 11, 2006 10:52 PM
1boostedcivic
Dec 14, 2004 03:51 PM
boostin b16
Mar 13, 2003 09:36 PM
true
Oct 10, 2002 11:47 AM
