Weird noise coming from walbro pump or fuel system when getting near low?
Old Dec 18, 2002 | 11:13 PM
sporkcrx's Avatar
Default Weird noise coming from walbro pump or fuel system when getting near low?
Well I would always hear this noise...sounded like a muffled v8 idle....hard to describe. Anyways, I thought it was an exhaust leak or something...but it figured out today it happens when I get near 1/4 tank and below on gas. The pump is a 255 walbro...I can hear the noise when the pump primes and at idle and driving...kinda sounds like a v8 idle or a coffey pot (some) sound when they're making coffey. It kinda freaked me out since the fuel cools down the pump...anyways, I'm just curious if anyone would know what the hell that sound is...and if it could of damaged anything.
Old Dec 19, 2002 | 02:15 AM
Tofurky's Avatar
Default Re: Weird noise coming from walbro pump or fuel system when getting near low? (sporkcrx)
take it out and inspect it
Old Dec 19, 2002 | 03:20 AM
1.8T_EG's Avatar
are you running an fmu?
Old Dec 19, 2002 | 05:37 AM
Doodoo's Avatar
Default Re: Weird noise coming from walbro pump or fuel system when getting near low? (Ruckus138)
Its not as easy as newer civics....not fun on a 4G.
Anyways, I haven't noticed any bubbling type noises. Mine does sound weird sometimes at low fuel. Mine seems to pump harder when the fuel is low, I think its supposed to do that. I have read it is not good to run a Walbro on a low tank of fuel. Does it still make the noise when the tank is full?
Old Dec 19, 2002 | 05:47 AM
turbod16y8's Avatar
Default Re: Weird noise coming from walbro pump or fuel system when getting near low? (Doodoo)
nothings wrong with it. mine sounded the same. sounded like there was air in the line. you should be fine.
Old Dec 19, 2002 | 12:54 PM
sporkcrx's Avatar
Default Re: Weird noise coming from walbro pump or fuel system when getting near low? (1.8T_EG)
at the time, yea
Old Dec 19, 2002 | 12:57 PM
sporkcrx's Avatar
No...when I found out it was the fuel system, I thought of the same thing I've heard, not good to run a walbro on a 1/4 tank or below...anyways, after filling the tank up, everything sounds fine. It just kinda freaked me out since I've heard that sound multiple times...and I've noticed my car seems to be slower at those times too, maybe it runs a little lean. But at least I know from now on to keep the tank nice and filled...just wondering what the hell the noise was.
Old Dec 19, 2002 | 12:59 PM
sporkcrx's Avatar
Default Re: Weird noise coming from walbro pump or fuel system when getting near low? (turbod16y8)
Yea, that's what I was thinking...air in the lines. So your car did the same thing eh? Cool, that's some relief then.
Old Dec 19, 2002 | 02:00 PM
333's Avatar
333
I also have a warlboro 255. Noisy. But thats what you get when you go high tech.
Old Dec 19, 2002 | 02:10 PM
Tofurky's Avatar
ah, ok. yeah for us, it's just a couple bolts, and out comes your pump.
but i do notice that when i am near empty, the pump seems to be get louder when i am low on gas.
Old Dec 19, 2002 | 03:46 PM
TurbothisLS's Avatar
yeah on the walbro's,
when low on fuel the pump will make a noise that is like scraping the bottom of the tank.
just don't run it on low fuel and you'll be fine
Old Dec 19, 2002 | 07:55 PM
turbod16y8's Avatar
Default Re: Weird noise coming from walbro pump or fuel system when getting near low? (TurbothisLS)
yea nothings wrong just another sound to add to for being turbo.
Old Dec 20, 2002 | 07:13 AM
swrdply400mrelay's Avatar
You guys are talking about the Walbro 255 intank pumps right?
I got the 255 Walbro High Pressure one and I can't hear it at all. Now I'm wondering if there's someting wrong with mine....
Old Feb 5, 2003 | 08:17 AM
genyosai's Avatar
Mine does the EXECT same thing. Mine is a Holley... but that's just stamped on the Walbro pump. I thought that something was blocking the pump screen inside the tank, causing it to work harder or something.
It never did this until I installed an AEM fuel rail, however. I wonder of the combination of low fuel levels and larger fuel rail cause this.
Old Feb 5, 2003 | 08:44 AM
Elite Hatch's Avatar
Default Re: Weird noise coming from walbro pump or fuel system when getting near low? (swrdply400mrelay)
Yours makes no noise??? That does seem kinda odd
Old Feb 5, 2003 | 08:48 AM
boostin b16's Avatar
Default Re: Weird noise coming from walbro pump or fuel system when getting near low? (Elite Hatch)
hell, mine is annoyingly loud when i go below 1/4 tank.....just keep it filled or it will lean out around sharp corners!
superbangkok
Oct 6, 2006 08:46 AM
Fat Chick Magnet
Aug 29, 2006 05:55 AM
B18C1 Civic EG
11
Jan 15, 2005 12:41 PM
speedymon
Oct 23, 2002 04:28 AM
td04civic
Feb 19, 2002 06:00 PM
