what are you guys opinions on my setup
ok i need opinions my set up consists of a t3t04 turbonetics with a ar of 50, all drag piping a 32 1/2'' x 10'' intercooler ,drag manifold and downpipe,delta gate with 6 psi spring and a stock block with stock injectors will i be ok the only thing i have to tune with is a vafc and a fmu w/ 12.1 disc
its all going on a 94 jdmh22accord, will i detonate after dyno tuning btw, i am running a p28 with a skunk2 chip
and yes i know i need a tial wastegate
First of all I'd like to point out how bad non-built H22s are for boost. That being said I'd def. recommend adding larger injectors and pump as well as colder plugs and a thicker head gasket to reduce compression. You may also look into gettin a Hondata or other unit so that you can fully tune it because the FMU and VAFC prolly arent gonna cut it. Finally I'd recommend NEVER going over the 6 psi until you have built the entire engine (rods,pistons,etc.).
Guest
Posts: n/a
True. I ran my h22 daily at 9 psi and even up to 14 psi a couple times (wastegate issue
). Everything ws good for at least 20,000 miles before I burnt one of my exhaust valves. Other than that everything has been good on stock internals.
try asking this in forced induction forum, i'm pretty sure you'll get more answers there.
i wouldn't boost an H22 like that. i'd take my time and do it right, so it can take the boost safely and save you many headaches.
i forgot to include that i do also have a intank walboro 255 fuel pump and colder plugs
boosted97lude<--- i started this thread because noone replied to it in the other thread
PM-Performance
Oct 22, 2002 12:23 PM
