HELP QUICK!! Question about trans fluid fill :(
Old Dec 18, 2002 | 01:11 PM
InjectedSS's Avatar
Default HELP QUICK!! Question about trans fluid fill :(
i cant get the damn bolt loose on the fill plug on the transaxle and i already ****** drained it! the idiot before me put gear oil in the trans and i had to change it out cause its been shifting like ****! my question is, is there any other way to fill the manual trans? thanks
Old Dec 18, 2002 | 01:19 PM
ndustryalGSR's Avatar
Default Re: HELP QUICK!! Question about trans fluid fill :( (InjectedSS)
An alternative would be to remove the VSS (vehicle speed sensor) from the tranny (screws in) and fill it up there. I know a lot of people who use this method. Some believe it easier than messing with that top fill bolt.
good luck.
Old Dec 18, 2002 | 05:46 PM
GSRaCeRbOI's Avatar
just get a breaker bar or a pipe extension for your existing ratchet for more leverage.... that should get it loose...
Old Dec 18, 2002 | 05:54 PM
hondamanwill's Avatar
becarefull not to break the tab on the VSS when you tightening it up
Old Dec 18, 2002 | 08:09 PM
Rtzx9r's Avatar
GDD 1%
Default Re: HELP QUICK!! Question about trans fluid fill :( (hondamanwill)
I just did mine on Saturday- sprayed PB blaster onto the bolts and let it sit... then had to use a 1/2 inch ratchet to bust the top one loose. It's friggin tight.
Old Dec 18, 2002 | 09:29 PM
Quik Chris's Avatar
Default Re: HELP QUICK!! Question about trans fluid fill :( (Rtzx9r)
Wait. Hold on. You can't get the drain plug loose, yet you already drained it? That doesn't make sense to me. You need a 3/8 drive socket wrench and a pump to get the fluid in. Put the socket wrench box on the drain plug (no socket, the bare box end will take care of it) and loosen. Then get a pump from checker or somewhere, and pump the oil into the tranny. VSS is a pain to get to, but can work if you don't have a pump. Then tighten up, no need to make it dificult.
Old Dec 18, 2002 | 09:39 PM
InjectedSS's Avatar
Default Re: HELP QUICK!! Question about trans fluid fill :( (Midori Shinkansen)
huh? no dude i cant get the FILL plug loose well i think i got it filled, i took that panel off that has like 8 bolts on it and then it pops off, well i took that off and got a transmission drain plug kit and basically drilled a hole in that plate, then used the drain plug kit to basically cover the hole and now i have a new fill plug i just filled it to the book specs and called it good thanks guys
Old Dec 18, 2002 | 10:42 PM
RedGSR's Avatar
I think it is better and safer to get a breaker bar and try to loosen the fill plug.
Old Dec 19, 2002 | 04:52 AM
Ricky Rojales's Avatar
Did you maintain the same height for the new fill hole? You CAN overfill the tranny... which is not good.
jrap1243
Jan 16, 2012 09:32 PM
ejpogi1925
Oct 2, 2008 03:08 PM
1uncleanDA
Nov 13, 2007 03:11 AM
watsvtecEK
Dec 22, 2005 10:33 PM
Re3irth
12
Sep 1, 2004 02:58 PM
