Need To take out the turbo for emissions
Old Dec 18, 2002 | 12:30 PM
1.8TypeR's Avatar
Default Need To take out the turbo for emissions
can anyone summerize wat i should and should not take out. i want to keep as much stuff on the car as possible. and steps on wat to take out first and etc.....
need to do it tonite. thanks, any help would be greatly appreciated.
Old Dec 18, 2002 | 12:52 PM
MyWhiteCivic's Avatar
Default Re: Need To take out the turbo for emissions (1.8TypeR)
I left my turbo on for emmisions, why do you have to take yours off? I have a drag kit too. I only needed to put my cat back on.
Old Dec 18, 2002 | 01:14 PM
accordfreak's Avatar
i'm interested in the answer also..
Old Dec 18, 2002 | 01:18 PM
E-Rok's Avatar
EPIC TUNING
hmmm just do it in reversal of intsallation? and get a plug for the oilpan. should be much easier than installing it.
Old Dec 18, 2002 | 02:36 PM
HXMan's Avatar
Default Re: Need To take out the turbo for emissions (rewsnaeht)
Should be easy. Just take off the mani, turbo DP...put stock exhuast back on, slap an intake on and go pass. You can leave the IC and other things in place. You could try to pass with the turbo first, and if you fail then take it off.
Old Dec 18, 2002 | 02:45 PM
DIRep972's Avatar
Smarter than you
Default Re: Need To take out the turbo for emissions (HXMan)
I just did it. well i took it off but i havnt gone to get my inspection yet. <lazy
i took off the upper charge pipe, manifold, downpipe, turbo and exhaust. plugged up the oil feed line and the oil pan. installed intake, stock header/cat/exhaust.
i hate my car now. and i think its slower then stock cause im running a hondata map tuned for boost and 550's. but i will be happy again in a few days.
Old Dec 18, 2002 | 02:49 PM
evoeone's Avatar
Default Re: Need To take out the turbo for emissions (DIRep972)
taking your T kit off for the night and returning to stock!!!!!!
ahhahahahahha, i highly doubt it will happen, throw 2 cats on there
good luck
nevermind, i was thinking of my car, where everything is in the back, and needs to be jacked, you honda guys prolly dont gotta jack the car up, and if so, not much, i envy you guys for having the turbo, wastegate, Dp etc alll in the front sshouldnt be that hard tho
[Modified by evoeone, 6:51 PM 12/18/2002]
Hybrid96EK
Jan 31, 2010 10:22 AM
SlowSOHC-T
Oct 26, 2007 04:09 AM
nota-ex
Jan 14, 2005 09:35 PM
PreludeSiTdriver
Dec 9, 2004 01:05 PM
TurBoXBirD16
Jul 13, 2002 07:48 AM
