what is this hole for on my turbo?
Old Dec 17, 2002 | 04:45 AM
rbf351's Avatar
Default what is this hole for on my turbo?
i'm pretty sure the hole is to connect a vaccum hose to the wastegate, but just wanna be 100% sure
Old Dec 17, 2002 | 05:25 AM
fsp31's Avatar
Default Re: what is this hole for on my turbo? (rbf351)
That would be my 99.99% sure guess as well...
Old Dec 17, 2002 | 05:28 AM
rbf351's Avatar
Default Re: what is this hole for on my turbo? (fsp31)
i was thinking about sealing up the hole and running the wastegate from the intake manifold, does that sound better?
Old Dec 17, 2002 | 05:37 AM
MiraiZ's Avatar
Its usually used as a boost source for a boost controller
Old Dec 17, 2002 | 05:41 AM
rbf351's Avatar
Default Re: what is this hole for on my turbo? (MiraiZ)
how come the company i got the revhard kit from said to connect that to the side port on the tial wastegate?
Old Dec 17, 2002 | 05:44 AM
xci_ed6's Avatar
I would guess that they said that becausse it is the port for the wastegate. The closer it is to the compressor th faster esponce the wastegate has.
-Dustin
Old Dec 17, 2002 | 05:45 AM
TurboedGSR's Avatar
because a revhard kit doest come with a boost controller. you can hook it up to your wastegate, but you will see less boost than if you were to use a vaccum source on your IM. i'd say plug it for now
Old Dec 17, 2002 | 06:10 AM
Mase's Avatar
Default Re: what is this hole for on my turbo? (TurboedGSR)
From my personal experience, I would run your wastegate vac source off the turbo as shown in the pic.
Reason being, a few months back, I had my wastegate tapped off the Intake Manifold, well low and behold, i couldnt figure out why i was only boosting 4 psi instead of 6. well i always thought it was the delta gate wastegate since i was getting atleast some boost.....
Turns out, i tore a rubber coupling and it was leaking boost, meanwhile spooling the **** out of my turbo. The wastegate never opened because it didnt see the 6 psi....
Moral of the story, Its safer to run the wastegate vac source off the side of the turbo.
alperx
Jan 24, 2012 12:22 PM
98integralsB18
Jul 25, 2009 07:29 AM
blu_si
Oct 1, 2002 04:20 PM
pelotudo
Aug 21, 2002 07:36 PM
JMinSi2000
Jun 18, 2002 10:12 PM
