wiring my s2k gauge cluster in my eg
Old Dec 16, 2002 | 06:14 PM
delux247's Avatar
Default wiring my s2k gauge cluster in my eg
ive seen this done before and i now have one and was hoping that some one could help me with some shortcuts before i dive into this project
any help will be very appreciated
Old Dec 16, 2002 | 06:16 PM
smnowell's Avatar
Default Re: wiring my s2k gauge cluster in my eg (egcivicturbo)
See if you can pick up the haynes manual from your local parts store. They should be like $12 or so. I am not sure if your EG plugs will go into the back of the S2K cluster. I have seen this done on another EG here...a while back though. Try a search for that thread...
Old Dec 16, 2002 | 06:17 PM
liam821's Avatar
25 Year Member
neat project! post some pictures when you got it done id like to see. When i did the wiring for my teg gauge cluster in my eg (ITR dash conversion) i used a volt meter, two wiring diagrams, two wiring harnesses, and some luck and found all the wires. You might want to try the honda dealer and see if you can photocopy a s2k wiring guide.
Good Luck!
liam
Old Dec 16, 2002 | 06:24 PM
YumVTEC's Avatar
go to your local dealership and ask to look at the ETM's(electronic troubleshooting manuals) for the 92-95 civic, and also the s2k, then flip to the pages that have the wiring pinouts for the cluster plugs and write down what each wire does.
Old Dec 16, 2002 | 06:34 PM
Nifty's Avatar
I remember seeing that a while back. I think he got the cluster to work fine except for the speedo. I suppose the S2k uses a different speed sensor, Or different wiring for it. Good luck! It will definately be sweet once you get everything going.
Old Dec 16, 2002 | 06:44 PM
Blue-Civic-Hybrid's Avatar
Loved
I wish you the best of luck, but I really don't know why you would want to do this? Just to be different? I love the way my S2000 gauge cluster looks, but in my S2000 only will it ever look right...but still good luck to you, i hope you get everything to work correctly, but i doubt it..
Old Dec 16, 2002 | 11:08 PM
civic23g's Avatar
Default Re: wiring my s2k gauge cluster in my eg (Blue-Civic-Hybrid)
Will look nice when its done.
Old Dec 16, 2002 | 11:13 PM
TurboBumblBee's Avatar
Default Re: wiring my s2k gauge cluster in my eg (Nifty)
that is correct.. a honda-tech member i think had it all wired in his EG and got everything to work correctly except the speedo and miles on the cluster.. different speedo sensors and resistance in the wire i think was the problem.. i dont think he ever got it to work correctly and it was taken out but im unsure.. do a search its somewhere to be found.. if you do get it to all work properly let us know cause ill swap out my gsr cluster for digital s2k cluster i hope your good w/ electrical wiring and figuring out how things work cause i heard it takes a lot to work
*edit* check out this link https://honda-tech.com/zerothread?id=280763
[Modified by 95CivicEX, 3:16 AM 12/17/2002]
Old Dec 21, 2002 | 08:06 AM
delux247's Avatar
Default Re: wiring my s2k gauge cluster in my eg (95CivicEX)
anymore help??? does anyone know this person who had it in there eg?
Old Dec 24, 2002 | 02:51 PM
delux247's Avatar
anyone helppppppppppppppppppp!!!!!!!!!!!!!
Crashtestdummy
15
Sep 10, 2010 11:33 AM
mikehawk
Nov 7, 2008 01:28 AM
nacho
Dec 10, 2004 11:41 AM
JUGGIEGAILS28
Feb 19, 2004 12:09 PM
Proper
Oct 21, 2002 12:06 AM
