wiring my s2k gauge cluster in my eg
ive seen this done before and i now have one and was hoping that some one could help me with some shortcuts before i dive into this project
any help will be very appreciated
Re: wiring my s2k gauge cluster in my eg (egcivicturbo)
See if you can pick up the haynes manual from your local parts store. They should be like $12 or so. I am not sure if your EG plugs will go into the back of the S2K cluster. I have seen this done on another EG here...a while back though. Try a search for that thread...
neat project! post some pictures when you got it done id like to see. When i did the wiring for my teg gauge cluster in my eg (ITR dash conversion) i used a volt meter, two wiring diagrams, two wiring harnesses, and some luck and found all the wires. You might want to try the honda dealer and see if you can photocopy a s2k wiring guide.
Good Luck!
liam
Good Luck!
liam
go to your local dealership and ask to look at the ETM's(electronic troubleshooting manuals) for the 92-95 civic, and also the s2k, then flip to the pages that have the wiring pinouts for the cluster plugs and write down what each wire does.
I remember seeing that a while back. I think he got the cluster to work fine except for the speedo. I suppose the S2k uses a different speed sensor, Or different wiring for it. Good luck! It will definately be sweet once you get everything going.
I wish you the best of luck, but I really don't know why you would want to do this? Just to be different? I love the way my S2000 gauge cluster looks, but in my S2000 only will it ever look right...but still good luck to you, i hope you get everything to work correctly, but i doubt it..
Re: wiring my s2k gauge cluster in my eg (Nifty)
*edit* check out this link https://honda-tech.com/zerothread?id=280763
[Modified by 95CivicEX, 3:16 AM 12/17/2002]
Crashtestdummy
15
09-10-2010 11:33 AM
JUGGIEGAILS28
02-19-2004 12:09 PM
Proper
10-21-2002 12:06 AM
