NX direct port 80 shot on this setup
I have a B16a1 w/ the following in my 88 CRX HF
ITR cams
ITR valvesprings
OBD0 - OBD1 conversion
Chipped P28 to DOHC
V-AFC.
Blah blah other bolt ons...
I want to add CTR pistons to the motor. With the 11:1 compression, how would this car like the 80 shot of nitrous? I am only considering Direct port. I have used zex and I know it is a beginer system. I want some serious power.
ITR cams
ITR valvesprings
Chipped P28 to DOHC
V-AFC.
You don't need bigger injectors to run that setup. If you go direct port just make sure to get a bigger fuel jet to help add the extra fuel while squeezing. The direct port is going to be harder on the motor, so keep that in mind.
dont bother w/ injectors or higher fuel jets. just get it dyno'd and find out what 80hp really equates to jet wise. if your going to build the head, jump to a 100 shot. id invest in an ignition..ie msd digi 6! by far the best for ur application. its got a lotta features especially suited for n20 and drag racing. if ya need a digi 6 i gotta sell mine so let me know, pm me if ya got any ?'s or need a new nx kit cheap.
roby
roby
