Need a diagram of the front suspension and chassis, please help!
I need a diagram of the front suspension and chassis of a 95 Accord EX. I took a quick look at the front right suspension on my car yesterday to see if I could find some of the bent parts from my curb incident https://honda-tech.com/zerothread?id=344885 . Anyway, There is a part that looks to be slightly torn and we need to find out what it is. I didn't get under the car cause it's outside in the cold and wet and wasn't dressed to get under there, basically just a quick inspection. The parts that I'm refering to is the part that the lower control arm bolts to. Not the outside end, I'm refering to the inside end of the LCA, like possibly the crossmember or something like that. Help me out please! Thanks.
Thanks for the diagrams. What manual did that come from, Helms?
Unfortunately the part that I'm trying to find is not pictured, or it is and I can't tell cause I don't know what the second picture is sorry. The part that I'm talking about is located just in front of the sway bar and the LCA bolts to it. Any ideas? Any help would be greatly appreciated, thanks.
the pic came from here, I think.
http://www.hondaautomotiveparts.com/...KA5MT&catcgry5=
Thanks, I think you helped me out a lot. I found a part called "cross beam" under the 1990 accord but not under the 1995 Accord. The cross beam looks similar to what I was looking at on my car but it's not list under the 1995's. Any opinions? Does this sound like the part I would need, only for the 1995 instead of the 1990.
You would have had to hit really hard to damage the cross beam. I really can't say without seeing it.
It's hard to tell which part by the diagrams, but I know what you're talking about. I just took mine out...
The first two pics I'm real sure about cause I haven't got under the car yet so I'll let you know on those. But in the mean time, If you look in the middle to upper right corner of the pic you can see where the LCA bolts to the part in question.
Thanks for the pics. Do you know what the part is?
if u need 94-97 suspension i have everything EXCEPT shocks and springs.. comes with cross drilled and slotted rotors and calipers... all that bullshit... email me at leenash23@hotmail.com
