motor running bad
ok my b16 is in and running compression is all good and everything...im throwing a code 6 which is coolant temp...at idle it sounds and runs fine...when i drive it...it boggs like CRAZY...it doesnt have any power or anything...can it be because of my gas that is 89 octane and has been sitting in my car for a year thats causing motor to run bad or is it a screw up in my wireing? write back asap!!!
make sure you have all your plugs in the back hooked up right...also check your timing and make sure its not off...set it at tdc and check if all the markings match up
also i got my wiring digram from hasport and i wired those 4 wires into my ecu but for a8 there was already a wire in it so i took it out and put the vtec solenoid in there...anyone have a diagram for every pinout for hf to pr3??? or if no diagram atleast a list of them...thanks
[Modified by RaceFacer, 4:04 PM 12/12/2002]
918-Hatch
24
Nov 14, 2006 07:20 AM
