HELP bogging/hesitation/shaking problem with my motor
Old May 17, 2003 | 08:06 PM
E-Rok's Avatar
EPIC TUNING
Default HELP bogging/hesitation/shaking problem with my motor
ok tonight i was just driving along and all of the sudden the car started to shake and lost all of its power. now it idles at 300rpm's, and when i rev/accelerate it shakes REALLY hard and hesitates like crazy. its runing like complete ****, not even driveable. it has all new plugs, wires, cap, rotor, vaccuum lines, fuel filter, and a half tank of gas. i have NO idea whats wrong. no CEL either. im stumped
Old May 17, 2003 | 08:10 PM
fizzbob7's Avatar
Default Re: HELP bogging/hesitation/shaking problem with my motor (rewsnaeht)
check all your vacuum lines and your ignition components....see if you can tell if it's running rich or not....did you possibly get any water in the distributor
Old May 17, 2003 | 08:11 PM
Chiovnidca's Avatar
Is it running on all 4 cylinders?
Old May 17, 2003 | 08:21 PM
E-Rok's Avatar
EPIC TUNING
Default Re: HELP bogging/hesitation/shaking problem with my motor (Chiovnidca)
like i said it has all new vaccuum lines and theyre all hooked up. itslate out so i havent checked all the cyls. tomorrow i will do a compression check and see how the park plugs look. it FEELS like its running on half the cyls or something tho...
Old May 17, 2003 | 08:25 PM
HondaD15BtoB16A's Avatar
Have you checked your motor mounts? One could have a shot bushing or be loose creating problems for wiring harnesses
Old May 17, 2003 | 08:26 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewsnaeht &raquo;</TD></TR><TR><TD CLASS="quote"> tomorrow i will do a compression check and see how the park plugs look.</TD></TR></TABLE>
Sounds like a good place to start.
Old May 21, 2003 | 06:46 PM
speedaccordinly24's Avatar
ive had the same prob. i cant figure dis **** out.
Old May 21, 2003 | 06:56 PM
1_bad_EF's Avatar
Default Re: HELP bogging/hesitation/shaking problem with my motor (speedaccordinly24)
check plug wires-for some stupid reason NGK(and maybe others) wires fall off the distributor
pull the valve cover and timing cover and check that the timing belt didnt slip a couple of teeth. cam(s) UP mark compared to the white line on the crank pulley(TDC).
jdm91integ
Jun 27, 2014 03:00 PM
Yeah Daybid
May 23, 2009 07:06 PM
jb0705
Mar 24, 2008 07:42 PM
xrocket21
Sep 30, 2004 02:58 PM
