nitrous bad for a jrsc...
if it is before the tb on say a dry setup i believe(and im could be wrong here) that it eats the coating or causes the coating to come off the charger blades. A direct port nitrous setup is in the im manifold runners after the charger blades so no problems with it affecting the charger.HTH
You can run a wet setup before the throttle body. Just don't run more than like a 50-60 shot. If you are going to run more, step up to a 4 fogger setup. Brian
jamal-188
Apr 2, 2002 12:54 PM
