non-firing injectors...??????????????????
im tryin to figure out why my injectors arent firing.....inhave a 91 b18a and it ran in the car i have it in.....all of a sudden it would just spin and spin and spin....i would like to know if anyone knows EXACTLY what would cause the injectors not to fire.....i swapped out the distributor....not knowing if either works now though....it will however start on ether....but then just stalls out....if you can help please do.....thank you
did u put the ground for the injectors?it should be on thermostst housing.
for sale!!!
bay area only<<<pick-up only<<i got this following stuff for sale:
92 ls motor /trany/ecu for $600 (rebuild motor trany no grinds)
93 prelude motor/trany/ecu for $1000(h23)(motor has 148000 mlz/trany no grind/still good compresion/needs water pump)
95 si trany for $200(no grinds)
92 ys1 trany for $400(da gsr)no grinds
92 integra trany for $200(no grinds)
94 si motor for $250(100000+ mlz)needs head gasket
pwo ecu for $100
cr/vtec motor for $1600. still in the car.no leaks.(b16 head /jdm b20z)
91 integra ls for sale >>$2500 210000+mls.
for sale!!!
pwo ecu for $100
Jordan Bishop
15
Mar 30, 2018 09:07 AM
jdmek2277
10
Nov 18, 2007 04:34 AM
