What turbo is on the starion/conquest?
Old Dec 11, 2002 | 01:43 PM
PrecisionH23a's Avatar
Default What turbo is on the starion/conquest?
does anyone knwo what the stock turbo is?
Old Dec 11, 2002 | 02:58 PM
AbaZ's Avatar
Default Re: What turbo is on the starion/conquest? (GudeH23a)
TC05-12A-8CM2
Mitsu Style Turbo, with a circular inlet flange, I belive the internal wastegate is set at 7psi.
Jeff Frank
http://www.homemadeturbo.com
[Modified by AbaZ, 7:50 AM 12/12/2002]
Old Dec 11, 2002 | 03:27 PM
wanttorace's Avatar
Default Re: What turbo is on the starion/conquest? (AbaZ)
ya what he tired to say was it is a 14b same thing of the first get dsms
Old Dec 11, 2002 | 07:48 PM
AbaZ's Avatar
Default Re: What turbo is on the starion/conquest? (jjd493925)
What I tired to say? you mean what I tried to say?
I told him what the turbo was, model/flange and internal wastegate setting... Sorry but the 14b is Not even close to this turbo... Compresser is differnt, as well as the exhaust port config...
Jeff
Old Dec 11, 2002 | 07:49 PM
GSRrR's Avatar
The newer ones with an IC has a wastegate set at 9psi.
Old Dec 11, 2002 | 08:00 PM
ViperRedCRX's Avatar
Default Re: What turbo is on the starion/conquest? (GSRrR)
i thought it was a te04
Old Dec 11, 2002 | 08:16 PM
Forgive my lack of knowlege on mitsu type turbo's, but if i were to order a flange to make a turbo manifold for, what type/part number flange would i need? 12a circular?
[Modified by GudeH23a, 12:16 AM 12/12/2002]
Old Dec 11, 2002 | 10:52 PM
AbaZ's Avatar
first off this turbo is to small for a H-series or even a bit undersized for a B-series.
The flange inlet is the same as DSM inlets.
Jeff
Old Dec 12, 2002 | 01:44 AM
one of my buddies had a conquest and ended up getting into a wreck. So his little brother has a crx with a ZC motor and is doing a DIY turbo kit, so he jumped at the opportunity of getting a free turbo and a couple other things.
Old Dec 12, 2002 | 05:01 AM
civictypenos's Avatar
seems to me if that small of a turbo can push a 2.6 liter,it should be able to push a zc.
Old Dec 12, 2002 | 06:51 AM
GraphiteAccord's Avatar
Default Re: What turbo is on the starion/conquest? (civictypenos)
its all about compression, and how much the head flows. look at the dsm crowd, how many of those guys have 60-1's? very few, look at honda-tech...a boatload of people have 60-1's on 1.8's...
Old Dec 13, 2002 | 09:26 AM
SilviaS14's Avatar
anthony...i'm tellin u its a 12A.
Old Dec 13, 2002 | 10:32 AM
RGAZ's Avatar
New User
Default Re: What turbo is on the starion/conquest? (SilviaS14)
Yep, Frank is right. Mitsu TD05-12a
Smaller than a 14b. Good for a Yugo, no idea why it was on the 2.0+L dodge.
The t-25 is small for a D16a6 and its bigger than it. The 14B is Ok for the D16a6. That thing on a ZC would be like choking your chicken...er I mean choking the engine. minimum for a ZC would be 14B, or t3 60 trim.
Randy
[Modified by RGAZ, 2:34 PM 12/13/2002]
Old Dec 13, 2002 | 11:35 AM
Spunkster's Avatar
It all depends on what year StarQuest it's from. Pre 1986 models had much smaller non intercooled turbos. 1986-89 models came with a slightly different turbo which differed in size and trim. The wastegate is easily Adjustable and can take about 10 psi stock. The problem with these cars is that the ECU has a boost cut. This boost cut differed greatly throughout the 86-89 models. On the 87 it is a td05-12
I own both an ITR and the 87 Conquest. The Conquest is here in SoCal and is for sale. $2300 OBO has 77K miles.
omghiii
Sep 8, 2008 11:48 PM
SBCCIVIC
Jun 21, 2004 06:50 PM
Bailhatch
Aug 7, 2003 07:35 PM
B20-T
Jul 28, 2002 12:39 AM
AbaZ
14
Feb 24, 2002 06:17 PM
