can running open header hurt your motor?
Old Dec 11, 2002 | 01:20 PM
slowone's Avatar
Default can running open header hurt your motor?
i heard this from a friend. i was just wondering if it is true/false.
Old Dec 11, 2002 | 01:22 PM
B2FiNiTY's Avatar
Default Re: can running open header hurt your motor? (slowone)
Worst it does it just run rich.
Old Dec 11, 2002 | 03:13 PM
Extent's Avatar
Default Re: can running open header hurt your motor? (B2FiNiTY)
the conserns I heard about it before was that cold air could easily run into your engine and cause it to cool too rapidly, causing dameage, a full exhaust makes sure that cold air dosent make it in. but I'm not sure how much of that I belive...
Old Dec 11, 2002 | 05:37 PM
Shawn C's Avatar
In The Garage
Default Re: can running open header hurt your motor? (Extent)
the only thing ive ever heard ( and i dont know if its true) is that running an open header ( or like a 3" straight pipe) is bad for the valves. never thought too much into it, though. im sure if you only do it at the track, it wont hurt anything. ( hopefully you wouldnt run that setup all the time, so i dont know why i said the track thing) oh well
Old Dec 11, 2002 | 06:32 PM
Lsos's Avatar
I don't see why it would damage anything. I don't believe air could get sucked in there....it's the exhaust, after all.
And besides, cold air gets easily into the engine through a cold-air intake anyways.
[Modified by Lsos, 3:34 AM 12/12/2002]
Old Dec 11, 2002 | 06:53 PM
MistaKilla's Avatar
Don't think it hurts your motor, but it sure decreases power in a stock motor. I would know. I'm the only idiot that likes the excessive noise and lack thereof power.
Old Dec 11, 2002 | 06:56 PM
satan_srv's Avatar
Since when does cold air rise?
Old Dec 11, 2002 | 07:28 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: can running open header hurt your motor? (22lbGS-R)
yeah i heard (keyword:heard) it can burn out yer valves easier, but i think thats just far fetched, i wouldnt really pay any mind to it, besides, im sure yer not gonan run open header for extensive amounts of tiem, good luck!
Old Dec 11, 2002 | 08:00 PM
slowone's Avatar
Default Re: can running open header hurt your motor? (SIXTYdashONE)
thanks for the info guys. i feel better now. you see i put a race header on my 97 lude and b/c it's longer there's no room for the cat. i'm in the process of having a pipe made, but the shop i'm going to is real busy right now. currently rolling in my gf's car--just in case.
Old Dec 11, 2002 | 09:25 PM
Lsos's Avatar
My car was a couple tenghts faster with open header. 89 crx dx w/ b16
Old Dec 12, 2002 | 02:22 AM
Extent's Avatar
Default Re: can running open header hurt your motor? (satan_srv)
I didn't mean while the engine was running, but as soon as you turn it off all of the air circulates. The hot air in the exhaust moves up and out and is replaced by cooler air surrounding. good point on cool air coming into the engine on me.
Old Dec 12, 2002 | 08:39 AM
qtiger's Avatar
People tend to confuse running open head and open header when relaying information. Running open head is ridiculously bad your your engine. Open header is just fine.
Old Dec 12, 2002 | 12:11 PM
allmotorEG-SI's Avatar
Default Re: can running open header hurt your motor? (qtiger)
I always heard it was the back pressure story. You know, not enough back pressure and its bad for the valves. I've been told thats mostly and old wifes tale with the old school domestic guys.
Old Dec 12, 2002 | 01:25 PM
gsrvx's Avatar
New User
Knocked a couple tenths off my time
Old Dec 12, 2002 | 05:33 PM
ITR21's Avatar
yeah thats what people are sayin but i doubt it would really damage anything
Old Dec 12, 2002 | 05:35 PM
ITR21's Avatar
Default Re: can running open header hurt your motor? (gixxerdemon)
it has nothing to do with backpressure,,,,,back presure is bad
Old Dec 12, 2002 | 07:19 PM
zlambe's Avatar
Default Re: can running open header hurt your motor? (ITR21)
More backpressure is good for bottom end torque, smaller amounts better for top end power, No backpressure is bad.
Old Dec 12, 2002 | 07:50 PM
fivil's Avatar
Default Re: can running open header hurt your motor? (zlambe)
Lots of bad information going around. Running an open header can (notice I did not say will) make you run LEAN at high rpm. This is because of higher flow rates and loss of pulse wave scavenging. I doubt you could damage it running that setup if it's a stock motor hooked to a stock ecu, but you can always try...
Old Dec 12, 2002 | 07:53 PM
texan's Avatar
Backpressure is always a bad thing, it means resistance to airflow. Being that an engine is primarily an air pump, resistance to airflow is not going to help anything, ever. The term you're looking for is delta pressure, which is a good thing as it describes velocity gain from the port to exhaust primary. Not enough velocity promotes reversion, and reversion is always a bad thing too (in terms of power output at least).
Old Dec 13, 2002 | 05:57 PM
myhatchrips's Avatar
Default Re: can running open header hurt your motor? (texan)
open header offers minimal gains. those quick 8 all motor guys run OPEN HEADER because their engines have been built to suck in as much air and scavange it out as fast as possible. a built head with the right valve train would benefit from open header. common bolt ons on a fairly stock engine, its not gonna do anything except sound louder. cold air going through the engine is good because its entering the engine and travel through the tb,then the intake manifold, which then the INTAKE valves open up. on the COMPRESSION stroke both intake and exhaust valves are closed. during the POWER stroke both intake and exhaust valves are closed. on the EXHAUST stroke intake valves close exhaust valves open which in turn comes out the exhaust system. if you run open headers and for some reason you car backfires say at high rpms, then cold air will be allowed to enter through the header contacting the HOT EXHAUST VALVES which will result in warpage.
Old Dec 13, 2002 | 11:00 PM
Lsos's Avatar
Default Re: can running open header hurt your motor? (myhatchrips)
Like I said, I was a couple tenths faster with open headers (on many, many occasions), going from upgraded exhaust. I was about .4 sec faster going from stock DX exhaust to the upgraded exhaust, which gives a total of over half a second and around 4mph difference going from stock dx to open headers.
So, it depends on what kind of exhaust and engine you have. Crappy exhaust and great engine gives huge gains, good exhaust with crappy engine will offer minimal gains.
Old Dec 13, 2002 | 11:07 PM
Goldfingiz's Avatar
I've also heard that it's bad for the valves.
A friend of mine had to run open header to meineke, and he said his car was DIRT slow.
Goldfingiz
Old Dec 14, 2002 | 01:55 AM
jdmWONG's Avatar
Default Re: can running open header hurt your motor? (Goldfingiz)
every car ive seen running open header has ran a faster quarter mile than with an exaust on. i went from a 14.6 to a 14.3. a freind of mine went from a 14.7 with his stock exaust, to a 14.2 with open header. then we ran it with slicks and eventually got it down to a 13.9. both were in i/h/e b16a crx's
Old Dec 14, 2002 | 02:30 AM
gsrvx's Avatar
New User
Default Re: can running open header hurt your motor? (Blow'N'CRX)
i went from a 13.9 to 13.7.
Old Dec 14, 2002 | 10:19 AM
MikeMAN's Avatar
i think the only thing it will hurt is your ears
jr408
Mar 20, 2008 09:20 AM
NinjaTech
Jun 19, 2005 08:56 PM
Nova_Dust
Jun 4, 2005 07:05 PM
00WhiteEKy
May 5, 2003 01:15 AM
CC2
Aug 26, 2002 05:59 PM
