Is it safe to run around on the street w/o timing belt cover?
Old Dec 11, 2002 | 06:53 AM
civicmatt's Avatar
Default Is it safe to run around on the street w/o timing belt cover?
I see alot of people doing it and I'm getting an adjustable gear for my cam soon. Is this safe for everyday street driving?
Old Dec 11, 2002 | 06:56 AM
Spade's Avatar
Default Re: Is it safe to run around on the street w/o timing belt cover? (civicmatt)
nope
Old Dec 11, 2002 | 07:39 AM
Briman2021's Avatar
Default Re: Is it safe to run around on the street w/o timing belt cover? (Spade)
nope
Can you explain why??
I was wondering the same thing and would like to know why it isnt safe.
Thanks!
Old Dec 11, 2002 | 08:01 AM
-Whitey-'s Avatar
Default Re: Is it safe to run around on the street w/o timing belt cover? (Briman2021)
the only covers i use are the lower outer one for timing and the sheild that goes around the cam gears on the valve cover
Old Dec 11, 2002 | 08:17 AM
mantic6t9's Avatar
Default Re: Is it safe to run around on the street w/o timing belt cover? (one-syk)
Say you're driving down the road minding your own buisness.A truck pulls out in front of you and there are rocks falling off the bed and bouncing all over the pavement in font of you.One of those rock bounces up into engine bay and lodges its self in inbetween your timimg belt and gears.That would not make for a happy engine.Pluse things can just fall in there.
Old Dec 11, 2002 | 08:31 AM
nsxmatt's Avatar
Default Re: Is it safe to run around on the street w/o timing belt cover? (mantic6t9)
Plus exposing your belt to the elements could reduce the useable life of the belt
Old Dec 11, 2002 | 08:46 AM
Beave0101's Avatar
Default Re: Is it safe to run around on the street w/o timing belt cover? (nsxmatt)
Keep them on, and when you go to a meet or wanna take pics of your engine bay, take it off just for show, if thats what you want to do, but why would you want to for daily driving ?
Old Dec 11, 2002 | 09:04 PM
civicmatt's Avatar
Default Re: Is it safe to run around on the street w/o timing belt cover? (Beave0101)
I think it would be alot easier to adjust a cam gear.
Old Dec 11, 2002 | 09:18 PM
Slow CX's Avatar
To heavy.
skunkwhat's Avatar
But I still have mine off
Old Dec 11, 2002 | 09:20 PM
ImportechPerformance's Avatar
Default Re: Is it safe to run around on the street w/o timing belt cover? (skunkwhat)
OF COURSE!!!! its safe to run around the street w/o timing belt cover! what dork
but just dont drive your car like that
Old Dec 11, 2002 | 09:33 PM
Ivan's Avatar
senior gold member
good example I wouldn't do it personally for the reason above but its your car and your motor.
Old Dec 11, 2002 | 09:35 PM
ace1875's Avatar
Default Re: Is it safe to run around on the street w/o timing belt cover? (TheRedSkoolingBus)
No Dork what if its raining and you have 78,000 miles on that belt SLIP!!!! and guess what!!
Why do you want it off for show!! think long life think smart your not on a dyno to have it off all the time....
or you can get you an extra from the junkyard and cut the exact holes for the entire cam gear and put it on for show and durin winter put the full cover
Old Dec 11, 2002 | 10:09 PM
IntegD's Avatar
New User
Default Re: Is it safe to run around on the street w/o timing belt cover? (ace1875)
Which cover are you referring to? The cover behind the gears and belt.....well, Ive been running without that one for a little over a year now, no probs. If you are talking about the cover that goes in front of the belt, then just cut the valve cover. Makes cam gear adjustments easy and also shows off the bLinG bLiNg yO.
Old Dec 11, 2002 | 10:24 PM
mattcxb18's Avatar
it is on for a reason
Old Dec 11, 2002 | 10:32 PM
spladam02's Avatar
Default Re: Is it safe to run around on the street w/o timing belt cover? (mattcxb18)
seems pointless to not have it on.
Old Dec 11, 2002 | 10:51 PM
ill phil's Avatar
Default Re: Is it safe to run around on the street w/o timing belt cover? (spladam02)
I realize that your thought process behind this was easing the ability to tune your cam gear(s), but in the best interest of your belt- leave it on. Honda does put it on in the best interest of keeping their economy car running as long as possible, just take it off when you hit the dyno and can truly tune your cams.
Old Dec 11, 2002 | 11:01 PM
ace1875's Avatar
Default Re: Is it safe to run around on the street w/o timing belt cover? (ill phil)
Its the most important belt and gear to be messing arround with one false move due to mother nature and you might be looking for a complete engine buildup!!!
is that something you want well if you got $$$ then don't care but if you are like me and tryin to save every buck then go safe.
If some of you where fortunate then you got lucky some people live south some way north I live in MEMPHIS and after i bought my Civic i pulled a CarFAX when buying it. It was manfactured in Canada and been passed like a **** in 7 different states!!!!
Best have two one for car shows another closed OEM type for daily driver
Old Dec 11, 2002 | 11:05 PM
JDMvtecDRAGSTA's Avatar
i woudlnt take the chance one time my friends car had a piece of concrete lodged between the lowest cover and the timing belt, and was eating away at the belt, good thing we caught it before it snapped
Old Dec 11, 2002 | 11:13 PM
ace1875's Avatar
Default Re: Is it safe to run around on the street w/o timing belt cover? (Mr. Sparkle)
exactly my point
I know it looks cool for them dual\single cams rotating but it doesn't look good roolin with a snaped belt.
masonracing
Mar 9, 2011 03:34 PM
LS_VTECteggy
Jun 11, 2010 01:34 PM
dominate9
Sep 28, 2005 04:07 PM
CRX Lee
10
Jul 27, 2005 04:48 PM
stupidfast
Oct 22, 2002 12:58 PM
