orEngine help.........head gasket
Old Dec 9, 2002 | 12:12 PM
Noe Kozz's Avatar
Default orEngine help.........head gasket
I have a question.
I have a leak by the cam gears, on the top hand right side of the valve cover. I already know I have to replace my valve cover/head gasket, maybe both. My question is, today while driving to work, I noticed a "clacking" noise whenever I hit between 3,000-4,500 RPM's (maybe more, but I didn't want to stress her). Is there something more to this than just the gasket/valve cover being replaced? Will this sound go away after those parts are replaced or am I looking at something more (maybe spark plugs). I hope it has nothing to do with the cylinders or anything. Any suggestions would be gladly appreciated and taken note of.
Old Dec 9, 2002 | 12:16 PM
b19coupe's Avatar
Default Re: orEngine help.........head gasket (VTEK 4 U)
What engine? What kind of fluid is leaking? Any work done on the engine recently?
Old Dec 9, 2002 | 12:20 PM
Noe Kozz's Avatar
Default Re: orEngine help.........head gasket (b19coupe)
it's a d16 Si ('93)
No engine work as of recently, it's leaking oil, I know I have to replace the the gasket/seal but I hope it's nothing more ($$$).
Old Dec 9, 2002 | 01:12 PM
b19coupe's Avatar
Check your cam seal while you have the valve cover off. It could be leaking.
Old Dec 9, 2002 | 02:05 PM
tnbigdawg's Avatar
Old Dec 9, 2002 | 02:52 PM
Noe Kozz's Avatar
Default Re: orEngine help.........head gasket (tnbigdawg)
Thanks guys, I appreciate the help.
Uljima
Oct 16, 2015 01:02 AM
ludesleeper
Feb 21, 2003 12:10 PM
sivik2nr
Nov 26, 2002 12:30 PM
Qwikrex
Nov 18, 2002 02:13 PM
04accordV6
Jun 14, 2002 10:27 PM
