Stripped bolthole in compressor housing ? trouble?
Old Dec 9, 2002 | 06:14 AM
PM-Performance's Avatar
Default Stripped bolthole in compressor housing ? trouble?
well from rotating the housings trying to get everything to line up nice , one of the holes got stripped out . its on the comrpessor housing . all the rest are fine and this one is in , but not tightly. will this cause me probs? or no? should i just retap it?
Old Dec 9, 2002 | 06:16 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Stripped bolthole in compressor housing ? trouble? (itr206)
yeah, just retap it. I dont know the tread is, but I would like to know...
art
Old Dec 9, 2002 | 06:18 AM
Default Re: Stripped bolthole in compressor housing ? trouble? (Arturbo)
aight thanks. ill let you knwo the thread when i find it . . . if anyone else knows off hand that would help alot
Old Dec 9, 2002 | 06:19 AM
legendboy's Avatar
You may be able to get away with just leaving it out if its one of the 6 bolts holding the housing to the cartridge.
Old Dec 9, 2002 | 06:25 AM
Default Re: Stripped bolthole in compressor housing ? trouble? (legendboy)
yea its just one of the bolts you need to loosen to rotate the compressor housing . like i said its in there, just not tighlty , all the tohers are fine though.
Old Dec 9, 2002 | 08:36 AM
Full-Race Geoff's Avatar
usually that thread is M8x1.25. assuming that it is a garret or turbonetics turbo. you can retap (actually more like chase the threads to clean them up a bit) and then if there isnt enough meat (youll know becuase you wont be able o tightne the bolt, itll just spin) i have some helicoils, i think i have a 8x1.25 layin around if you need it. good luck!
btw you can usually find the m8x1.25 tap at any auto parts store.
Old Dec 9, 2002 | 08:42 AM
Default Re: Stripped bolthole in compressor housing ? trouble? (FFgeoff)
yea its a Garret . . . whats a helicoil? sorry it might sound stupid to you , but i never heard fo that before
Old Dec 9, 2002 | 08:43 AM
Flamenco-T's Avatar
use 8x1.25 tap, and use a short bolt
blackeg
Jul 15, 2012 05:33 AM
freakie
Apr 10, 2008 04:08 AM
ncskate
Feb 22, 2005 08:05 PM
RNPoo7
Jan 7, 2005 09:54 PM
94EGhatch
Aug 16, 2004 07:50 AM
